Engine Squeal 2015 JCW
Hi all!
I've had my Mini JCW for a little under 2 months now. It's done 1750miles. It was built in August 2015.
Usually I do only short journeys, due to a change in nature of business I've been doing some long journeys recently, on every single one of my long journeys(2hrs+) I get a squeal eventually that comes from the engine bay.
It's through 1st to 4th gear between 3k RPM and 4k RPM. Very annoying and very loud - AND EMBARRASSING!!
It's exactly like I've seen in other threads but the difference is this car was not built in 2014 like all the others & I would assume they fixed the quality issues from last year (crankshaft)?
It's annoying that I've paid £32k for this car and in under 2 months I get these issues.
Was just wondering if anyone had an answer for what is going wrong?
It's booked into the dealer for next week although I gotta feeling its going to go around in circles as they won't be able to reproduce the symptoms as it only happens on long drives
Here's a video that my sounds exactly like:http://rocspocs.tumblr.com/post/1207...i-engine-sound
Any ideas??
Any ideas??
Wow. You would have to ask the question..what is the thing that gets hotter after 2 hours? and is not after an hour...?
Can't tell from the clip but is it like a slipping belt sound? In my limited experience anything oil related would be at full temperature after 20 minutes. Maybe a blow off valve....
Hmmm exactly....I can't put my finger on it either. I'm not a mechanic by any means but I have a fair bit of knowledge about cars! Definitely wasn't a belt slipping... I'm thinking something to do with transmission.. Although that's a guess!
Again it does also sound like a vacuum leak or air leak. But the car drives perfectly.
MINI called earlier and confirmed the booking for next Thursday. Doubt they'll come back with anything though!
Call dealer, tell them that it happens after a long drive and try to arrange that they test drive it with you after you've already been driving for and hour or more. Then don't stop the car or let them out until you hear it. Kidnapping is legit in these circumstances.
What was the final resolution? Mine just started to do this exact same thing not too long ago.
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
