F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
F56 find the rattles!
Old May 15, 2015 | 05:01 AM
  #126
GregoryK's Avatar
GregoryK
Originally Posted by g34343greg
I would definitely push the dealership to replace your shocks. It makes a huge difference and if Mini Engineering ever decides on a real, permanent solution you'll still be able to get that if/when it appears.
Greg. I agree on the temperature. Hopefully the new cars are better than this....with it not happening at all!
Old Jun 15, 2015 | 07:50 AM
  #127
jorafagoro's Avatar
jorafagoro
They replaced the lower control arm bushings on the right side to cure the clunky noise I was getting with the clutch and low speed bumps.
It seems to have done the trick. The tech called mini and they had seen this before and told him to replace them as he actually couldn't find anything.
Greg, this noise gone for good in your car after the intervention?
In my car I exchanged the support of the engine and continues to make noise.
Now they tell me to do a test on a car just like to see if it is a normal noise ...
Old Jun 17, 2015 | 08:32 AM
  #128
g34343greg's Avatar
g34343greg
yes, this definitely fixed that issue.
Old Sep 19, 2015 | 12:17 PM
  #129
Ih8driedfish's Avatar
Ih8driedfish
So replacing the lower control arm bushings and/or rear suspension fixed the knocking sound?
Only asking because my GF and I own 2 '15 MCS (one is a lease, other we own so I can mod!) and both have the same sound/issue only at low speeds on a bumpy surface. Its been a few months but heard the same sound in two loaner vehicles as well so I thought it was "normal". Will contact my SA.
Thanks for posing the useful info!
Old Oct 7, 2015 | 04:26 AM
  #130
g34343greg's Avatar
g34343greg
For my fellow owners who have dealt with the rear suspension knock-
I've seen some improvement with the new set of rear shocks over the last few months. It doesn't bother me as much as it used to since everything in the interior seems to rattle.
anyways, I got a call from the dealership yesterday saying that there is a new design for the rear shocks. I don't know how it's different, but they said I could bring mine in and have the new parts fitted. I guess I'll have to get that scheduled, so I'll be sure to update this when it's done.
So if you have the "knock", now's the time to start bugging your dealership again!
Old Oct 7, 2015 | 12:43 PM
  #131
MidnightF56's Avatar
MidnightF56
Has anyone encountered the high-pitched squeaking from the front axle over broke pavement or cobblestones? There's a TSB out there but my dealership doesn't seem to be responsive to the the cause of the issue, and I'm wondering if anyone could give me details on a potential fix.
Old Oct 10, 2015 | 11:02 PM
  #132
blue al's Avatar
blue al
It's beginning to chill down in the uk and I've noticed the rear rattle
October 2014 built SD with the variable dampers
Anyone with hard info on the uk recall,
I would like to nail this with one trip to the dealers if possible
Old Oct 19, 2015 | 02:59 AM
  #133
BennyF's Avatar
BennyF
Originally Posted by GregoryK
Greg. It is interesting to me that you are having to prove to your dealer that something is wrong. BS in my opinion. My dealer took my word for it and did not take the car for a drive till week after they ordered the parts. This whole issue is well known. There were recalls in the UK.
Time to change shops imho.
Hello, what year and build month is your car. Is it the MCS or Base
I have a small know int he rear over mild bumps, but I was told it is to mild to replace anything, just need to break it in. I have about 1500 miles.
Old Nov 18, 2015 | 01:59 PM
  #134
UticaProf's Avatar
UticaProf
My dealership has finally ordered the redesigned rear suspension parts. Now that it's turning colder the rattle is becoming more annoying again, so it will be good to finally get this taken care of.
Old Dec 6, 2015 | 06:13 AM
  #135
UticaProf's Avatar
UticaProf
Just to follow up, the redesigned shocks were installed, and so far it has taken care of the rattle, and I actually think the ride is a bit smoother as well.
Old Dec 6, 2015 | 08:09 AM
  #136
BennyF's Avatar
BennyF
What kind of rattle was it. What build date is your car.
thanks
Old Jan 1, 2016 | 07:36 AM
  #137
UticaProf's Avatar
UticaProf
As others have said, it was a rattle (originally on one side) from the rear suspension, and it worsened as the weather got colder. Loudest under 15mph going over bumps. Now it's gone.
Old Jan 1, 2016 | 09:15 AM
  #138
honderpilot's Avatar
honderpilot
Rattle or creaking sound?
Old Jan 6, 2016 | 05:01 PM
  #139
UticaProf's Avatar
UticaProf
Rattle, as if something was loose in the right rear wheel well.
Old Jan 16, 2016 | 09:15 AM
  #140
twentytwo's Avatar
twentytwo
My 2015 F56 has been in the shop since early this week troubleshooting for the 3rd time the suspension noises. Control arm bushing has been replaced and they are thinking of replacing the strut assembly. The original control arm bushing they said was leaking. Had to order a new one from Germany. The car makes a creaking/squeaking/knock kinda noise when turning left and going over rough pavement or bumps. It's a lemon in my book. The car is nothing but trouble and I'm sorry I ever leased it. Not as good as my 2009 Mini.
Old Jan 16, 2016 | 03:01 PM
  #141
vetsvette's Avatar
vetsvette
Moderator
I don't really have any rattles, but I do get a clunk from the rear end when I go over bumps. Seems to happen more often when the suspension is unloaded.
Old Jan 31, 2016 | 05:16 PM
  #142
wilbee50's Avatar
wilbee50
Rattle
My 2015 Cooper S 2dr has a nasty rattle in the rear. Our roads are horrific mainly because of the 120 degree temps we get every summer. We just got back from a short drive and I climbed in through the hatch since we keep the back seats down, and my wife dove me around. All I had to do was touch the plastic inside the hatch and it stopped. Will be letting the dealer know so they can hopefully fix it.
Old Feb 1, 2016 | 08:49 AM
  #143
bctf1's Avatar
bctf1
Wilbee50, I had the same exact rattle in my 2015 2 dr. Turned out that the latch and the tension adjusters had to be adjusted. Poof, rattle is now gone.
Old Feb 1, 2016 | 11:07 AM
  #144
wilbee50's Avatar
wilbee50
Thanks for that info Brad
Old Feb 13, 2016 | 09:09 AM
  #145
VYPUR's Avatar
VYPUR
Thanks for the info..mine is in the shop for that as I type this.
Old Feb 16, 2016 | 01:54 AM
  #146
BadakVT's Avatar
BadakVT
Hi guys,
Two days ago my car has developed a nasty rattle on the left-side rear quarter panel.
Spent all day today trying to track it down, even teared down the interior panel with no luck.
I've tried the seat belts, handle bars, moon roof, speakers, amps, cables, clips, insulations, and it's none of the above. The only place I couldn't get to is the lower half of the body panel cavity. There's a rigid plastic divider secured by some kind of soft expanding foam. This divider is just below where that mid-bass speaker is. Tried accessing it from below the car but also no access. Forcing access there would mean permanent damage to the expanding foam stuff, so I'm seeking help before doing that.
Any help would be greatly appreciated!!
Here's a video of the rattle:
Here's the rear interior panel for reference (clip locations):
Old Feb 16, 2016 | 05:08 PM
  #147
jaep1911's Avatar
jaep1911
You need to change the video to "Unlisted" rather than "Private".
Old Feb 16, 2016 | 07:03 PM
  #148
BadakVT's Avatar
BadakVT
Thanks for catching that. Video privacy has been changed.
Today I'm planning to check all suspension parts before cutting the cavity shielding.
It really sounds like the noise is coming from below cavity shielding (part 5) on diagram below.
Old Aug 7, 2016 | 10:24 PM
  #149
rmcintos's Avatar
rmcintos
2015 F56-S at 30k. Got a few notable noises.
- High pitched squeak in the front dash, down low inside the center section, seems behind the AC control area. Sounds like a little bird chirping away when on a bumpy road.
- Rattle in the boot or hatch. Nothing loose back there. Maybe inside the hatch door or in the roof area above the hatch.
- Moonroof makes a horrid creaking/cracking noise when going over a bump to turning the car into a driveway. It's almost like the whole car flexes and bends when you hit a bump. Both my girlfriend and I both have F56's and both our moonroofs make these creaking sounds.
Taking it into Mini next week for them to hopefully start the hunt. If anyone has any simple suggests or fixes, or have found the cause the similar sounds... please let me know here.
Old Aug 7, 2016 | 10:33 PM
  #150
hp79's Avatar
hp79
Did you ever get this fixed? My 2015 F56 had rattles in the rear, I think it's from that spot you pointed. I just stuffed a used cloth inside there like a year ago and then didn't pay attention to it. I think that solved it, but it might be that I haven't driven enough lately and not noticing it.
Last time I drove my F56 was to replace the leaking rain sensor gel from the front mirror. I could hear rattles from the door speaker grille. I don't know why they make it so flimsy. It's only been couple days and my rain sensor gel pack is leaking again. I wiped it off this time with the cover taken off. I'll keep an eye on it and probably take it back if I see it more than 10cm of the gel leaking on the windshield.
