F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Advice needed
Old Dec 4, 2020 | 07:19 AM
fozzy2k's Avatar
fozzy2k
Advice needed
Ok so I bought a 2017 mini clubman about 4 months ago, when I took it for a test drive it felt very good but I noticed the steering wheel wasn’t square when driving in a straight line and was slightly off to the right, the garage said they could fix that no problem, it’s now straight but It doesn’t feel very firm while driving and feels as if there’s slight play in the steering now, do anyone know what could cause this?
Old Dec 4, 2020 | 07:38 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
My guess is they just adjusted the tie rods to get the wheel straight.
You probably want to get a precision alignment performed. Make sure camber, caster and toe are in spec, and are the same on both sides. Even if both sides are within spec, if they aren't the same values on each side, handling and feel can still be wonky.
Old Dec 6, 2020 | 11:47 AM
fozzy2k's Avatar
fozzy2k
That does sound like something they said, is this the correct way to get the wheel straight?
Old Dec 6, 2020 | 01:31 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
It is, as long as the alignment is starting out good. If the steering wheel is off, you turn one tie rod this way half turn, and the other tie rod that way half turn. Done.
Old Dec 7, 2020 | 02:29 AM
Sahbaz's Avatar
Sahbaz
Your car is still under warranty
Go to Mini dealership and let them take care of that
Miniminic
Sep 16, 2020 04:53 AM
spearre1
Dec 27, 2019 10:26 AM
Buckey
May 21, 2018 10:34 AM
LeftyClayJar
Jan 17, 2015 01:22 PM
Califzeph
May 6, 2006 09:37 PM
