F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Brake Light Malfunction - Repair?
Old Dec 30, 2018 | 09:27 PM
pickjs's Avatar
pickjs
i am receiving a brake light malfunction error that comes on and off. does anyone know how to replace the bulbs? i have been searching for a video or manuals but can't find the instructions. thanks for any tips
Old Dec 30, 2018 | 09:30 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
should be here https://www.newtis.info/tisv2/a/en/f...q=replace+bulb , although I didn't read it.
Old Jan 8, 2019 | 06:52 PM
ZiaMan24's Avatar
ZiaMan24
If your car is still under warranty, Mini will replace it for free
Old Jan 23, 2019 | 11:24 AM
JohnnyQuest's Avatar
JohnnyQuest
Ummm, the procedure for removing the bulbs starts on page 222 of your owner's manual, which is in your glove box, or accessed here: https://www.miniusa.com/owners/tools...r-manuals.html You can also access a digital version of the owner's manual from the center console without even getting out of your car. But you'd have to read the owner's manual to know that! :-)
You just remove the tow hook cover and unscrew a set screw. Mini even gives you a screw driver as standard equipment! (But again, you'd probably have to read the manual to know that!) There are so many interesting things in the owner's manual...Anyway, it literally takes about 20 seconds to pop out the tail light assemblies and check the bulbs. (I've done it, so I'm not exaggerating. 20 seconds. Ok, 60 seconds for your 1st time.). You have to insert the screw driver at an upward angle. If you use a small flash light, you will immediately see the screw that you have to turn.
GDGR
15
Aug 10, 2017 06:44 AM
mini4door
R60/R61 Stock Problems/Issues
Jan 28, 2013 06:15 AM
eenunez1
Jun 10, 2012 08:46 AM
Cooper Guy
Aug 12, 2007 07:39 PM
anon0mus
May 31, 2006 10:18 PM
