Electrical 12 VOLT POWER SUPPLY WIRE
Old Feb 23, 2007 | 08:38 PM
mcnamaraz's Avatar
mcnamaraz
Hey guys. Making an attempt to install some gauges and I need to locate a wire behind the speedo, or in another close location to the tach, that is a 12 volt supply. I have located the illumination wire...but cant find a power supply wire. HELP please.
Old Feb 24, 2007 | 07:04 AM
bryan1970's Avatar
bryan1970
just check the wires that are back there and see if any of them give you 12V when you want it? be real careful of bus wires behind the cluster. in fact i would recomend not using wires form behind the speedo. the best way to install in my opinion woud be to run wires for your gauges from a power block or the battery and run an inline fuse.
Old Feb 25, 2007 | 05:50 AM
NMgokart's Avatar
NMgokart
What type of 12v supply are you looking for? Always on; on with key on, on with dash lights on...?
If "key on, power on", try the radio circuit or the lighter circuit. You can use a fuse-tap at the fuse box. Just don't overload the circuit!
Old Feb 27, 2007 | 01:23 PM
jwardell's Avatar
jwardell
The best way is to go through the fuse box and properly tap it. I have that documented here:
http://www.jwardell.com/mini/fusetap.html
Wohnson89
Jun 10, 2020 04:53 AM
Mb460
Aug 20, 2016 10:39 PM
Super Coop
Aug 17, 2015 05:09 PM
yashmack
Aug 15, 2015 03:11 PM
minipopkart
Aug 13, 2015 05:22 AM
