Electrical Mounting Radar Detectors
Old Feb 23, 2007 | 08:07 PM
PezRadar's Avatar
PezRadar
How are people doing this in your 07's?
It feels like I can't with my suction cups on this car since the window is far too vertical. Wasn't sure if anyone else with an 07 was doing anything different.
Old Feb 25, 2007 | 07:08 PM
dwdyer's Avatar
dwdyer
I drove home with my RX65 mounted with cups about two inches or so off the dash. The vertical slant of the window works fine, but took some tweaking of the bracket (and will likely need a bit more) to keep the detector against the glass and not rattling. What's more of a problem is the curve of the glass. You really need to keep it centered, which means you need to run it a bit higher than you might otherwise, to keep the driver's side wiper from interfering.
Old Feb 26, 2007 | 06:17 AM
rhawth99's Avatar
rhawth99
I velcro my detector to the dash on all of my cars. Although this is not the ultimate location, I prefer to keep my detector out of sight of prying eyes. In the MINI, I have a small base that I mount the detector to.
Old Feb 26, 2007 | 01:44 PM
illeagalhunter's Avatar
illeagalhunter
Iam getting a defusser fitted ,a detector will have busted a defusser will mush the radar for 7 secs to let you get on the brakes on
Old Apr 19, 2007 | 10:33 PM
msh441's Avatar
msh441
My Escort Pasport 8500 works fine centered and obout 3-4 inches off the dash..
Bent the bracket down a bit (opened up the angle) before clipping in the detector.
Old Apr 21, 2007 | 09:02 PM
jduvall's Avatar
jduvall
My Passport sits perfectly (with suction cups) right between the headliner and the rear-view mirror (hardwired into fuse box).
Old Jan 16, 2008 | 11:42 AM
imbz's Avatar
imbz
http://www.countryjoycrafts.com/Conn...arDetector.htm
Old Jan 16, 2008 | 12:02 PM
lacning74's Avatar
lacning74
I visor clipped my Ecort 9500i to the headliner edge just to the left of the rear view mirror. Also used some hook velcro tap to stick it to overlying headliner to keep it from bouncing or sliding sideways. BTW, it's hardwired tucked along the headliner down the A-pillar weatherstripping and to the fusebox.
It's not easy to remove where I put it, so it won't work well if you remove yours after you park.
Old Feb 16, 2008 | 11:41 AM
shooler's Avatar
shooler
This is the way I have my Bel mounted, and so far, I like it a lot. It's a very nice and well designed part.
Old Feb 16, 2008 | 06:10 PM
Minidrivr's Avatar
Minidrivr
Visor clipped my V1 to the headliner just to the right of the mirror, slightly behind it.
Old Feb 17, 2008 | 05:33 AM
Bor's Avatar
Bor
my install is very similar to Lancing74's.
here is the picture of it:
https://www.northamericanmotoring.co...6/ppuser/16452
I'm using a 5$ clip for the Escorts that I got from Amazon.
Old Aug 6, 2008 | 11:01 AM
maxx629's Avatar
maxx629
Mounting of Whitler Pro 78. I mounted my RD above and to the right of the mirror. I have it wired using fuse #42 (lighter 20A) and grounded it in right side of the glove box. The wiring tucked up behind the weather seal and under the headliner, makes a clean install.
Thanks everyone that has posted their installs
ground location
Old Aug 12, 2008 | 03:22 PM
k6rtm's Avatar
k6rtm
To the right of the mirror clipped to the headliner similar to what Maxx did -- very difficult to see from the outside. I picked off power from the switches and lights in the top centre; the radar detector powers up when I unlock a door, and powers down 20 minutes or so after I shut things down or lock the car.
Filmy
15
Jun 6, 2023 06:27 AM
elverado
Jan 18, 2022 02:51 AM
minimofo
Sep 30, 2015 12:26 AM
caiken
Sep 7, 2015 09:10 PM
Sep 4, 2015 02:34 PM
