Electrical O2 sensor wide or narrow??
Old Jan 23, 2007 | 05:41 PM
schooner2's Avatar
schooner2
So I want to put in a air/fuel gauge, But i need to know from the experts, should I install one with a wide or narrow band sensor? and can i hook a norrow or wide band sensor to any gauge?? Thanks for any input!!
Old Jan 23, 2007 | 05:52 PM
ScottRiqui's Avatar
ScottRiqui
Given the choice, a wide-band would be more useful, since the narrow-band ones are only accurate when you're right around 14.7:1. In fact, they're really not much good outside of 14-15:1 range. A wide-band sensor can accurately measure from 10-20:1.
Wide-band sensors generally require a specific gauge, since the voltage output varies over a wider range. A narrow-band sensor voltage might only swing from 0-1V, where a wide-band sensor might go from 1-3V.
Old Jan 23, 2007 | 06:03 PM
rough68fish's Avatar
rough68fish
What do you want it for
IMO unless you want a light that goes back and forth like the one on "Kits" hood the narrow band is worthless. If you actually want to tune with it I would go beyond just a wide-band to one that can acutally log data against rpm and time.
Old Jan 23, 2007 | 06:44 PM
isellem's Avatar
isellem
you only want a wide band. A narrow band will tell you nothing other than.. well... other than... you have a blinking light like the kit reference in the earlier post
The wideband 02 is the only way to go. It will actually tell you what you need/want to know.
Don't waste your time with a narrow band.
i don't mean to come across as negative. I just want to make sure you don't waste your hard earned dollars!
Old Jan 23, 2007 | 06:59 PM
schooner2's Avatar
schooner2
The way I look at it, is this could be cheap insurance, even though my car is not the most mod car on the street, I think its to the point it would be nice to be able to monitor the air/fuel. here is a list of what the car has, tell me what you think, should i be worried?
2004 JCW
-jcw injectors,
-jcw ecu upgrade to go with injectors
-Shcrick cam
-2% crank pulley
-alta intcooler
-alta CAI
- soon to be installed is a custom tuned Unichip!
Thanks for all the input!
thadscottmoore
Jun 4, 2021 07:19 AM
shorenetworks
Nov 4, 2019 06:18 PM
CaptKen
R59 :: Roadster Talk (2012+)
11
Oct 21, 2015 06:32 AM
sempaipaul
Sep 18, 2015 03:05 PM
Norton70
Sep 7, 2015 05:06 PM
