Electrical water temp.gauge
Old Sep 11, 2006 | 10:13 AM
leon lindberg's Avatar
leon lindberg
water temp.gauge
I have a '05 mini cooper s. I need to install a coolant temperature gauge and would like to know if there is a place on the engine for a mechanical gauge. And also an oil pressure gauge.
Old Sep 11, 2006 | 06:55 PM
One-D's Avatar
One-D
www.bentleypublishers.com
Mini service manual.
www.mossmini sells the manual for $84.95 (Part No. 100-067)
You want an electrical gauge, both water temperature as well as oil pressure.
Oil pressure, you buy a tee to mount both the factory one and the aftermarket gauge one.
Water temperature... don't have clue where to tap. Perhaps there is a location within the engine block --- a service manual can help you
Old Sep 13, 2006 | 05:59 PM
90STX's Avatar
90STX
Another option is a Scan Gauge II. It reads from the OBDII port, and will display numerical readings for four sensors at a time. Choices include coolant temp, intake air temp (post intercooler), manifold pressure (boost, in absolute values), timing, throttle position, closed loop vs open loop, actual mph, rpm and probably something else I'm not remembering right now.
The coolant temp reading is actual, not what is displayed on the factory "gauge". Same for mph. The MINI speedo reads high but the ECM knows the real speed and that is what comes through the OBDII port. If you've changed tire diameter, you can adjust displayed speed up and down in 1% increments.
Display backlight color is user editable, and includes an amber that matches the factory lighting quite well.
http://www.scangauge.com/
Scott
90SM
Old Sep 14, 2006 | 09:59 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
I installed a 'true' water temp gauge on my '03 with nav (which has no gauge at all, just a light). I used the block drain plug just above the starter. This area is in direct contact with engine coolant flow, unlike solutions which use a tee to mount a sensor in the radiator hose. Such installations tend to read lower in normal operating conditions, and very low before the engine reaches operating temperature and the thermostat opens (until that time there is no flow in that hose).
The block drain port is a common 3/8" pipe thread (not metric). Note that the starter is in close proximity to the port, and depending on the design of your sensor, you might have to loosen the starter in order to have clearance to thread the sensor in. Most mechanical gauges have a rather large sensing bulb with capillary tubing and required adaptor nut and as such wont fit. Any single-wire electric temp sender will fit without problems or a need for starter removal. I installed a full-sweep (270 degree needle swing) Auto Meter temp gauge which has a two wire sender which needed the starter to be dropped.
Note that in order to work in this area, you have to remove the exhaust header for clearance. Simply remove the header flange and pipe joint and lower the header rather than removing it entirely. Use a bucket to catch the coolant that will escape, and return it or replace it when done.
USNAE2
16
Jun 17, 2022 07:17 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
ian260
Mar 29, 2017 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
martinb
Oct 7, 2015 05:00 PM
