Electrical OEM alarm questions
Old Aug 22, 2006 | 09:38 AM
  #26
FlynHawaiian's Avatar
FlynHawaiian
payed $56.25 to have it activated at bob smith.
Payed like 190 for the alarm. It's so fast to install. The hardest part was the new stalk, but that took like 10 minutes.
Old Aug 22, 2006 | 09:41 AM
  #27
Eric_Rowland's Avatar
Eric_Rowland
Originally Posted by madmike007
Easy to install, although the siren was a bit of a pain because I dropped the bolt and had to fish it out. Other than that, the install was relatively simple...
Been There, Done That. Got the @%^#$%& T-shirt.
Tools required:
t-20 torx bit
10mm socket
SMALL HANDS
Old Sep 2, 2006 | 06:37 PM
  #28
jody's Avatar
jody
Anyone installed a after marker alarm system?.
Old Sep 3, 2006 | 06:05 AM
  #29
umberto's Avatar
umberto
yup...a year and half ago I installed a $35 audiovox alarm that uses voltage drop to set it off....if a door is opened and light comes on it sets it off....also has adjustible vibration/shock sensor...no motion sensor but hey, it was only $35 and I was able to easily install it myself....the only problem I see with it is it means an extra FOB on my key ring, but it is much smaller than our LARGE key
note: on other threads elsewhere it has been mentioned, and verified, that holding the key up to one's chin will extend the range of the remote.....that works, and it also works with my alarm FOB, as it more that triples the range
Old Sep 3, 2006 | 06:12 AM
  #30
umberto's Avatar
umberto
where does the OEM horn get installed? I found darn little room to put the little audiovoxx unit...I installed mine as high up as I could right in the middle below the windshield vents, in a plastic piece right behind(actually towards the rear of the car) the engine
Old Sep 3, 2006 | 08:20 AM
  #31
Eric_Rowland
The OEM siren/tilt sensor is installed in the hollow on the passenger side just in front of the windshield vent and next to the ABS module.
Old Jan 8, 2007 | 04:38 PM
  #32
ChrisO's Avatar
ChrisO
Alarm Wiring
Originally Posted by JCWGrover
The early MINI's did not come with the alarm wiring installed, it was part of the kit, and had to be put in along with the alarm, hence the 4 hrs and install price quote of $500. As of present, all MINI's have the wiring pre-installed, nd the alarm installation consists of simply plugging in the modules, and then having the system coded to recognize the alarm.
I have an '04 MCS, does that come with the Alarm Wiring Installed? What year did the change take place?
ChrisO
Old Jan 10, 2007 | 10:01 AM
  #33
Eric_Rowland
Yes, your '04 is pre-wired. They started adding the wiring in late '02 or early '03.
silence2-38554
Nov 12, 2015 09:39 AM
blackie
Oct 2, 2015 07:41 PM
blackie
Aug 23, 2015 08:44 PM
FLYM1N1
Aug 16, 2015 01:15 PM
