Electrical The yellow light at the end of my windsheild wipers flash when i start the car!
Originally Posted by ruggedbert
I only used them 4 times!!
its an 06!
its an 06!
Perhaps the dealer forgot to top it off when you picked up the car?
The '05/'06 tank is about double the size of pre-'05s!
What I'd really like is for that low fluid light to flash when I switch off & get out - it expects me to notice it flashing AND remember all the way home. No chance
Originally Posted by Dolmangar
I was only joking, hope that it came thru with the smilely
Just wanted to clarify that with the newer MINIs, we are sooo lucky to have such a big washer fluid tank - why I can get nearly 2/3 of a bottle of fluid in now if it's empty
Well...just to let you all know....Mike had the "flashing" issue in his - it started shortly after we took delivery and it "flashed" all the time - LOL!!! ...and guess what? Everything was FULL....we had it to the dealer twice and they finally replaced a malfunctioning part....crazy....
Donna
Donna
my yellow blinky just came on (hidden behind the wheel and not that noticable actually) and I don't seem to have any fluid in the rear line.
1) do front and back wiper fluid jets operate from the same source? I have front fluid.
2) is there a danger to having a possible air bubble in the line? Thanks.
Its more than likely the one of the fluid holders are near being out of fluid. The rear sprayer is a pain in the butt.... If you stop paying attention to it, it won't bug you anymore. I am use to it going off... They run out fast. I think they only hold enough for 3 sprays and thats it... Good luck Spike
The front and rear share the one bottle - in fact they share the one PUMP.
If you have a second bottle, it is for the Xenon headlight washers.
If fronts work and rear doesn't, I think you might need to visit the dealership - but first fill up the bottle to make sure it's not a low pressure thing.
Thanks. Got the fluid, haven't put it in yet. Ought I "cut it" with H2O or fill it straight from the jug?
(I'll check, but the fronts were working the other day. I guess I COULD drive to ATL this weekend...)
It is appropriate because MIB was flashing at us last week. MIB has Xenons and to fill both tanks took over 3/4 jug of washer fluid!
