Electrical HELP! My stereo no longer recognizes my Aux Input.
Old Jan 24, 2006 | 02:34 PM
minithemoocher's Avatar
minithemoocher
Hi everyone!
So, last Spring I installed the aux input into my MCS. Worked like a charm! The stereo instantly recognized the aux input and I was able to connect my iPod. Happy motoring! Last month I started up my MINI and noticed that the aux mode was not available! D'oh! Please note, this was after not driving for around a month in the early part of Winter, so the battery discharged quite a bit (yeah, yeah... I'm using a battery conditioner now ). I've done everything I can think of to try to remedy this. I've unplugged and replugged it. I've disconnected and connected my battery. Also, I've confirmed that the wiring harness is fine. I installed it on another MINI and it works perfectly. Does anyone have any idea why this happened and how I might go about resolving it?
BTW, I simply popped the knee bolster beneath the steering wheel and reached behind the stereo to insert the wiring harness into the back of the stereo. Yeah, there's no need to remove down tubes and pull out the stereo. Why spend $200 or more at your dealership to have them drill holes in your glove box? Click here for the instructions I used, care of Sean Bartnik. Thanks Sean!
All the best!
Old Feb 2, 2006 | 09:43 PM
CruiseControl's Avatar
CruiseControl
Mine recognizes it when it feels like it. And when it is working, it will only work for about ten minutes before it swithces to another mode.
Old Feb 2, 2006 | 10:03 PM
Motor On's Avatar
Motor On
GLI I'll post a link to explain in a few Min.
Motor On's Avatar
Motor On
https://www.northamericanmotoring.co...d.php?t=59777&
Hope this helps
Old Feb 15, 2006 | 02:32 PM
garretwp's Avatar
garretwp
I had the same issue with my 05 MCS and installed a ground loop isolator. Works like a chram and had no issues ever since. I had been to the dealer about this issue many times and when I told them that i fixed it and what I did and they were shocked. I got this unit from radio shack:
http://www.radioshack.com/product/in...ductId=2062214
The mini's electrical system has noise in the lines and when the xm radio is plugged into the car, it emits noise in the audio feed which causes the aux input to be fussy and not work!
Garrett
Old Feb 15, 2006 | 02:36 PM
The MINITOR's Avatar
The MINITOR
Same here. Ground loop isolater fixes it, $16 from Radio Shack.
Old Feb 17, 2006 | 12:39 PM
CoryB
The Radio Shack GLI comes with one adapter to 1/8" audio plug. What did you do for the other end? Is there a part number for anohter 1/8" adapter?
Old Feb 17, 2006 | 12:47 PM
Poiman's Avatar
Poiman
I used the Radio Shack GLI also, but found this one:http://www.crutchfield.com/S-ty0Wni9...90&I=127SNI135
It is much smaller and works just as well.
Old Feb 17, 2006 | 12:52 PM
The MINITOR
It actually worked that way for me because it was going between a dvd player's rca's and the aux cable, but if you go the store I am sure you can find the other stereo rca to 1/8 adapter.
I saw the crutchfield too but wanted to pick one up right away so went straight to radio shack.
Old Feb 17, 2006 | 01:05 PM
garretwp's Avatar
garretwp
I had to get a rca to 1/8 adaptor that you can pick up from rat shack as well.
Garrett
RobbyD
Jan 29, 2019 01:22 PM
rikaro
Nov 24, 2015 02:05 PM
dutchhome
Sep 30, 2015 07:17 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
