Electrical Fuse for the remote lock / unlock?
Old Sep 14, 2005 | 04:58 PM
Rev. Limiter's Avatar
Rev. Limiter
The remote lock / unlock decided to quit on me. I know the battery is charged in the key, and figure the circuit for the remote is protected by a fuse. (?)
Anyone know which one it is before I turn "Sam" over to Dr. Hendrick in Charlotte? I hate to drive that distance just for a blown fuse.
Help, please?
And yes, I did a search on the forum, but couldn't find anything for the remote...
Old Sep 14, 2005 | 05:00 PM
chows4us's Avatar
chows4us
Wouldnt it be simpler to pop open the key, find the battery type and get a new battery?
Old Sep 14, 2005 | 05:33 PM
Rev. Limiter
It's not the key.
I found a hot wire for my radar detector and it worked fine until I found a pothole from He** on the way to D.C. (on I-95) the other day and it shorted.
Just can't find the right fuse...
Old Oct 9, 2005 | 03:46 AM
Arly's Avatar
Arly
fuse for central locking
The fuse is located at the top of the 3rd collumn of fuses in the fuse box in the car. It is a 20 amp fuse. It is the first one at the top of the 3rd collumn, according to my Bentley Manual for 2002 thru 2004 MINI Coopers.
Hop this helps,
Old Oct 10, 2005 | 05:28 AM
Rev. Limiter
Turned out that I had to "reformat" the key so it would talk to the car. My SA talked me thru it over the phone, and now everything seems to work okay. (Put the key in the ignition, turn to first click, remove, hold the wings down while pressing the unlock button three times - slowly - and it should work...)
I asked why the key would "forget" the code, and he said that he didn't know. But the more I think of it, the more I believe that the magnet money clip I was using was screwing things up. I know you are suppose to keep those money clips away from credit cards because it can scramble the info on the magnetic strip.
Old Apr 4, 2006 | 02:10 PM
sck_nogas's Avatar
sck_nogas
Okay, how does one do this? My key (with fresh battery) won't lock/unlock, but the fuse is not blown since the power lock switch works. My questions are...
1) After turning the key to the first click, how to you "remove" and what do you remove? IE> Do I turn the key back to "off" and remove the key? OR something else?
2) Pressing the "unlock button" do you mean the switch under the radio, or the unlock button on the remote. (Isn't that the "wings button"?)
3) How slow should this be done? Hold down the unlock button/switch for 3 seconds, pause for 1 second? Or 3 times within 5 seconds? or?
I've tried alot of combinations, and still no joy in mudville.
Scott
Old Apr 26, 2006 | 02:49 AM
wrecker's Avatar
wrecker
Tiffany at Motot City Mini coached me through this yesterday. This is for an 05.
Insert the key and turn to the #2 position then remove the key. Point the key at the rear view mirror, (Antenna), hold down the unlock button on the remote and hit the Mini wings (Lock) 3 times. You will hear the locks cycle through lock and unlock. Then you must do the second key right away, same sequence but do not put the key in the ignition, just hold down the unlock button and press the lock button 3 times.
Good luck!
Filmy
15
Jun 6, 2023 06:27 AM
Hobine
Oct 7, 2015 04:52 PM
TGlax38
Sep 16, 2015 07:26 AM
WillShootPhotos
Sep 14, 2015 07:50 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
