Electrical GBMini's circuit & modification
Old May 27, 2005 | 10:31 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Anyone know how easy it would be to mod the GBMini circuit to have the auto-disable DCS and such hooked up to a jumper or toggle or something.
I know it's not too difficult to toggle the automatic feature on and off but I think something like a jumper that could be rigged to a switch would be a little bit more elegant solution. That way I could install the circuit and rig a little switch under the toggle bank to enable/disable the functionality. (you know, something really inconspicuous and out of the way).
Old May 27, 2005 | 11:23 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I'm not really sure what you're asking. If you want to turn off the track mode function, hold your unlock button up for at least 5 seconds, then while still holding it up, press your DSC toggle down.
If just want to turn DSC on (say, if it's raining), hit your DSC toggle once in either direction.
Old May 27, 2005 | 01:06 PM
aminicooper's Avatar
aminicooper
Um... doesn't this sound like the way it comes from factory? A switch to toggle enable/disable functionality.
Either way, have you tried asking the question to the source of the GBMini circuit... himself?
Old May 27, 2005 | 06:31 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
yeah, I know, it's not that hard to enable disable, but what i'm looking to see if it was possible to modify it even farther to make it even easier to enable/disable the automatic DSC functionality.
Originally Posted by aminicooper
...have you tried asking the question to the source of the GBMini circuit... himself?
I was hoping he frequented here and would be able to anser this.
Old May 27, 2005 | 06:35 PM
mdsbrain's Avatar
mdsbrain
He does frequent here but dropping him an email is the best way. He is extremely friendly and helpful. I now have the Auto-up windows on our two MINIs.
Old May 31, 2005 | 07:27 PM
GBMINI's Avatar
GBMINI
Thanks to my friend Josh, I can now answer this ...
(yes I am on NAM, but as mdsbrain said, I don't see every post so a question direct might be best ... plus I have been away since Friday).
If I understand correctly, your best option CmdrVimes would be to cut the signal on the MINI circuit board which causes "track mode DSC" to occur. You could then wire an on/off switch to re-make / break that signal.
If you contact me direct (GBMINI@MINIsOnTop.com) I can give you details of exactly where to cut the track if you wish to go that way - then you need to have the soldering skills to add two wires to the circuit board, and take them to the switch that you install elsewhere.
vulkandino
Oct 31, 2015 08:29 PM
hays0023
Oct 31, 2015 07:52 PM
schr5530
Oct 5, 2015 08:28 AM
point665
Sep 29, 2015 12:41 PM
Mazarin
Sep 15, 2015 08:45 AM
