Electrical Wiring Questions
Old Mar 11, 2005 | 12:17 AM
regalic's Avatar
regalic
Wiring Questions
Couple of lighting wiring questions
What gage wire is used in the MINI, specificly for the lighting?
Where is a good grounding location in the rear of the MINI?
And finally can anyone tell me what each of these wires does on the rear tail light assembly for an 05 MINI?
The numbering is 1 on the left with the empty slot #6.
Old Mar 11, 2005 | 01:23 PM
regalic's Avatar
regalic
So no one knows anything about the MINI's wireing?
Anyone have a bently manual with the 04's rear tail light wiring and can list what each is for?
Old Mar 11, 2005 | 02:18 PM
regalic's Avatar
regalic
Well looking at the official 2005 taillight retrofit guide on motoringfile
http://motoringfile.com/howto/
2 3 4 and 5 all just go straight across so those are all the same.
Only thing that changes is the #1 pin. So in 02-04 that is the rear fog and in 05's it is the reverse.
Still need to find a place to ground my new reverse light and find out the wire sizes. Guess once I get off work I will go digging around the boot's trim looking for a spot.
Old Mar 30, 2005 | 06:15 AM
Jdewey's Avatar
Jdewey
wiring
Color codes on my 2004 MCS are at this address.
http://user.mc.net/~jdewey/MINI/Trai...olor_codes.htm
That looks like a ground stud with a black cap on it in your photo. There is one in the left fender well that you can see in this photo. I added the White wire to the existing stud. As I recall the same stud is in the right side.
http://user.mc.net/~jdewey/MINI/Trai...on_adapter.jpg
If you are going to wire something, You can remove each terminal from the plug, and wrap a wire around it then put it back in.
http://user.mc.net/~jdewey/MINI/Trai...MINI_wires.jpg
John
siriuszero
Sep 17, 2015 04:41 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
Getrieben
Aug 15, 2015 09:09 PM
yashmack
Aug 15, 2015 03:11 PM
