Electrical R60 - Coding in fog lights
Old May 4, 2024 | 11:35 AM
Alexr54's Avatar
Alexr54
Exclamation R60 - Coding in fog lights
This question is a bit specific and i suppose only someone really knowledgeable with this model would know this answer. So im trying my luck here as this is the only really good source online for this stuff.
My 2012 R60 came only with the very weak front parking lights.
I replaced them with LED Parking/Fog lights.
I've already got the parking light portion wired and working. Its the fog light part, with the way i am attempting to do this that is a mind bender.
The really important part is that I replaced the center console button module (The one under the module that opens windows and door locks on center dash) with a OEM module that has the fog light button.
Does anyone know how to get 12v (or whatever voltage power) from the button to the new parking/fog lights? Is there a wire/fuse i should look for or add?
Does the replacement module with the fog light button need to be coded in? If yes, does anyone know the daten name?
I have no problem with wiring in something new, or coding whatever is needed. I do have both a icom next (with fiber) and a carly. I even have a xtools d8s/kc100 for key fob programming
My problem is with knowing what to code in or what fuse/wire to add or look for. It obviously will not power anything on as is, since i don't have the OEM harness for the fog/parking lights, although if i knew what harness to get for it i would.
And i cant just hard wire the button, its all circuitry.
If i am unable to get any answer or help here i am hopeless. So i am praying some hero on this forum comes along and saves me
Old May 15, 2024 | 08:44 PM
Alexr54's Avatar
Alexr54
Fund these 2 VO codes
$520 - Fog lights
$5A1A - LED Fog lights
Alexr54
May 4, 2024 04:45 PM
rob_jones
Jan 22, 2023 04:48 PM
SOUNDAROUNDYOU
Sep 24, 2020 10:54 AM
phil_deez
Oct 13, 2016 03:26 PM
heiker
Electrical
May 14, 2014 03:14 PM
