Electrical Tap into Low Beam wiring?
Old Jul 2, 2022 | 08:39 AM
Here2Go's Avatar
Here2Go
NAM Community Team
I apologize in advance for a seemingly stupid question...I am not that electrically savvy when it comes to Mini's.
I have a pair of small (2") LED spot lamps I want to install behind the lower grill of my '04 pre-facelift R53.
I want to tap into the low beam wiring so they turn on when my headlights are on. Since I haven't found (or there isn't) a low beam fuse I can pigtail off of and I would prefer not to tap into the igniter (if at all possible)....Is that even an option?
What other simple options exist?
Any recommendations on how I can accomplished this would be very much appreciated.
Old Jul 2, 2022 | 11:50 AM
Capt_bj's Avatar
Capt_bj
the headlights are controlled by the Body Control Module / computer in the pss' side footwell (which also replaces the individual circuit fuse)
how you want to wire is essentially how the factory driving lights are wired, using the low beam trigger line as the feed to the relay. SOOOOOOO .... your attachment point would be the same as that shown for the driving light install . . .
https://www.minimania.com/pdfile/NMA3030_INSTR.zip
Old Jul 2, 2022 | 12:55 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Hey Capt -Thanks for that!
I was hoping not to add another toggle switch for these lights.
On a side note:
I actually have/installed the 5" Mini grille mount Spot lights. I installed/wired those differently from the directions supplied (as you've posted above) and modified the console switch panel by adding a factory toggle to the vacant (fog light) blank.
Thanks again.
Old Jul 4, 2022 | 07:13 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Nothing too Electrifying. Just Enlightened...
Thanks to the advice above - I was able to tap into the low beam head lamp wire and added a pair of small LED spot lamps behind the lower grille..
For anyone interested; The large white w/blue stripe wire is the low beam (on my PF '04 R53).
Nothing impressive. Just a couple of small LED Spots mounted behind the lower grille. The Spots are actually brighter/whiter than what appears in the photo.
Just a little extra added insurance in hopes to avoid hitting another cat.
Old Aug 7, 2023 | 04:48 AM
Onizukachan's Avatar
Onizukachan
Nice work.
Met wife at grocery store on Friday night after work since they had a sale with limit 2 on Dr peppers, so we could buy more for me.
on the way home I had all my lights on behind her (white fogs, white indicstors, lows, high and big Hellas) , and she said it reminded her of a little jumping spider with all the different sized eyes.
I can see in your pic what she meant!
The Rake
Nov 30, 2021 01:22 AM
Mooogden
Sep 6, 2019 10:38 AM
Elemento1991
Electrical
Sep 12, 2016 07:47 PM
opdokey
Electrical
Feb 25, 2011 07:53 AM
Cassy
Classic Mini Talk
Nov 7, 2006 06:55 PM
