Electrical Help needed Using Sport button to trigger a relay
Old Feb 25, 2020 | 09:29 AM
Chyperie's Avatar
Chyperie
Help needed. I have a Steinbauer power module on my cooper sd which can be switched off by earthing the appropriate wire. I was looking to use the sport button to trigger a relay to switch on the module by "unearthing" the wire. However I am aware from the amazingrando posts (to enable automatic switching on of sport mode) that this is not possible by just tapping into the sport button wiring. Any suggestions/help in resolving this issue would be appreciated. I could just use a remote switch to achieve the on/off function but feel it would be better using the sport switch.
Hope this makes sense!
Old Oct 31, 2020 | 02:10 PM
jetsr6's Avatar
jetsr6
Did you ever do anything with this idea?
Old Oct 31, 2020 | 02:16 PM
Chyperie's Avatar
Chyperie
No gave up and used a remote
Old Oct 31, 2020 | 02:45 PM
jetsr6's Avatar
jetsr6
I’ve been trying to use the oem switches for other purposes without luck. Like the defroster, rear wiper, even the heated seat buttons but I can’t get them to do anything. #becauseracecar
Old Nov 1, 2020 | 01:54 AM
Chyperie's Avatar
Chyperie
Yes, unfortunately gone are the days when switches were simple on/off circuit breaks!
Old Nov 1, 2020 | 04:03 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Welcome to the world of CAN bus wiring! Instead of opening and closing contacts, switches now pulse voltages through the wiring, which is monitored by the ECU. Depending on the voltage on that terminal, the ECU performs some function. In the case of the “Sport” button, the ECU will go into “Sport” mode. So, yeah, as you found out, you can’t just tap the wire to add additional relays.
This is also why the car starts to freak out when battery voltage gets low
wsalopek
Dec 12, 2017 10:56 AM
Ween
Mar 29, 2011 05:06 AM
onefish2
Electrical
Jan 16, 2009 07:50 AM
plin
Jun 13, 2008 10:34 AM
