Electrical Euro Spec Switch Panel
Old Jan 29, 2020 | 07:09 AM
Chase Haerr's Avatar
Chase Haerr
Alright so I'm looking at getting a switch panel from Europe that has all of the switches in it unlike the US ones that are missing one or a couple because I want a full switch panel for rally lights. The ones from Europe have ASC and the ones in the US have DSC. Will it mess with the computer if I put the new panel in? Also I'm trying to put the aux rally lights into the rear fog light circuit switch. Any Ideas on how to make the lights work off the rear fog light switch?
Old Jan 29, 2020 | 07:12 AM
Chase Haerr
This is the one I'm thinking about getting but I don't know if I will be able to tap into the rear fog light circuit after having it activated
Old Jan 29, 2020 | 07:31 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It's not a "euro" spec part.
We just call it a full toggle panel it's the same part for US or non US cars. The difference will be in the options the car had. Some cars had ASC and some DSC so it would just be based off which options the car had what it says, then if it did or didn't have front and rear fogs.
The switch panel is literally just a ground input to the body control unit so it doesn't matter what it says, it will work for a car with ASC or DSC as it's the same signal to turn either off.
After install you will need the car coded to make the rear fog lights work as the rest of the car is prewired for them.
We do have a used one in stock, otherwise we can get you a new one but it's over $300 for new now.
https://www.waymotorworks.com/used-f...0-r52-r53.html
Old Jan 29, 2020 | 07:47 AM
Chase Haerr
Thank you very much for the clarification. I don't know much about wiring do you have any tips on how to route my rally lights into that switch panel once I get the switch activated?
Old Jan 29, 2020 | 08:01 AM
WayMotorWorks
Vendor
you need to use a different setup for rally lights as this panel is just a ground input for the computer no actual current goes through it.
So in order for you to control other lights you would have to set them up to use a ground input which would be much more work.
Old Jan 29, 2020 | 09:33 AM
mountainhorse's Avatar
mountainhorse
Wonder if you can access that momentary ground signal from the "dead" switch position?
Then use a simple, stand alone, sealed latching relay and make a harness for that... fogs, driving etc... probably cheaper and less hassle than coding.?
Plus, you can then use a super bright LED for the lamp as opposed to the feeble 921 bulb that MINI uses.
Is there a wire in the connector going into the switch?
A latching relay would give you the same function... momentary-toggle on, momentary-toggle off.
Old Jan 29, 2020 | 09:56 AM
Chase Haerr
So there's no way to just hardwire my rally lights into the wire that would theoretically go to the rear fog light? I thought if there was a wire going out the back of the switch panel that would go to a rear fog light I might be able to just route that to the front lights.
Old Jan 29, 2020 | 10:51 AM
Paul's Avatar
Paul
Just add a switch to the knee bolster under the left air vent. Or if you have the parcel shelf, there's a switch blank already cut for the driving lights.
Old Jan 29, 2020 | 12:46 PM
mountainhorse
Since the factory 'switch panel' uses/provides a momentary ground (-) contact from the switch.... I'd imagine that it would be pretty easy to get a ground trigger signal from that and isolate it from the vehicles BCM.
Nice thing about the latching relay with the ground trigger... you can wire it so that it will go off and reset itself when the ignition is turned off !
Old Jan 29, 2020 | 01:33 PM
mountainhorse
Plus theres this from Socalva on NAM here...
https://www.northamericanmotoring.com/forums/electrical/337517-my-various-projects-auto-up-module-shift-light-atoto-a6-retrofit.html
https://www.youtube.com/watch?v=gGOcO-q0b1M
Originally Posted by socalva
Hi,
Thanks for reaching out. I do have some modules ready - I'm asking $100 shipped. I can program the boards before shipping with the settings you want as well - for example, if you already have auto windows on your driver side, it should be disabled on the module so it doesn't cause any conflicts, or I can just enable track mode, dual up/down, etc.. just let me know and include it in the PayPal notes. If you're ready to order, please paypal
AlvaAutoUp@gmail.com along with your NAM username, name and address, and default settings you want.
Current options:
  • Auto Up Driver
  • Auto Up Passenger
  • Auto Down Driver
  • Auto Down Passenger
  • Dual Auto Up (Both windows go up with double click of driver side button)
  • Dual Auto Down (Both windows go down with double click of driver side button)
  • Track Mode (DSC off on startup)
  • Auto Front Fog (turns on with headlight)
  • Auto Rear Fog (turns on with headlight)
I've uploaded two YouTube videos showing how to attach the module to the switch panel, and another on how to program the module.
Install
https://youtu.be/XaOk8EEVsGc
Programming
https://youtu.be/gGOcO-q0b1M
These are also firmware upgradeable, so if you think of any options you might want in future releases please let me know. Right now i'm testing UK mode which just swaps the drivers side window controls for dual up/down to the right of the switch panel instead of the left.
Thanks,
Luis
downhillspec
Apr 25, 2024 09:21 AM
Chase Haerr
Dec 24, 2019 03:18 PM
Dat240zg
Oct 14, 2013 08:13 AM
MLPearson79
25
Jul 30, 2007 11:34 AM
evanzrod
Sep 26, 2005 10:25 PM
