Electrical NCExpert Coding Question $522 VO
Old Apr 6, 2019 | 09:07 AM
mcaanda's Avatar
mcaanda
Picked up a set of new headlights for the R61 and have been reading about the NCE coding of it.
Question comes up - where is the addition of this $522 VO to be put?
Thanks ~
Old Apr 6, 2019 | 08:36 PM
Cab00se's Avatar
Cab00se
It goes on the Vehicle Order (VO) of both the CAS and FRM. Then you will also want to change the following:
Disables auto-leveling - in case you're not retrofitting that as well.
AUTO_LWR_ENABLE
nicht_aktiv
Also disables auto-leveling
DYNAM_LWR_ENABLE
nicht_aktiv
Changes headlight pinout to the 3 main pinout. Before adding $522 your car should already be using this but once you update the VO this is changed. This also fixes flash to pass.
PWM_FL_BEI_BIXENON
wert_01
wert_01
I actually just finished the same conversion myself using all OEM parts and will be doing a writeup once my remaining housing shows up next week.
Old Apr 8, 2019 | 10:32 AM
sub3622's Avatar
sub3622
AUTO_LWR_ENABLE
nicht_aktiv
DYNAM_LWR_ENABLE
nicht_aktiv
PWM_FL_BEI_BIXENON
wert_01
wert_01
I also want to do this but i´m not too confident in doing this yet. What year/model is your car?
Old Apr 17, 2019 | 07:47 AM
MiniToBe's Avatar
MiniToBe
bmwbrandon
Sep 9, 2014 10:52 AM
Chattmanlan
Jan 6, 2014 04:17 PM
Chattmanlan
Jan 5, 2014 04:31 PM
NintenTom
Tires, Wheels, & Brakes
Aug 21, 2012 11:05 AM
mikeyb74
Massachusetts Motoring Club
Jul 20, 2012 03:51 AM
