Electrical Radar Detector Mount For R53
Old Sep 19, 2015 | 07:34 PM
BRebels's Avatar
BRebels
I have an Escort Passport 8500 X50 Radar Detector & I'm trying to find a mount for it. The one that came with it cannot be utilized due to the rake of the Mini's windshield(2003 MCS).
If you have this particular model,what are you guys using?
My first preference is a mount for the rear view mirror.
Thanks in advance!
Old Sep 19, 2015 | 07:38 PM
bavmotors's Avatar
bavmotors
Depending on your style rear view mirror, there may be a mount that fits. I use a 3m adhesive Velcro for my x50 8500
Old Sep 25, 2015 | 01:25 AM
Eric_Rowland's Avatar
Eric_Rowland
For my Valentine, I use the 'visor clip' clipped in to the headliner on the left side of the rear view mirror. Just fits.
Old Dec 3, 2015 | 02:34 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I've mounted it up by the rear view mirror with the suction cups and routed the wire through the headliner and down to the power source. I've also done this directly above the steering wheel on the highest point of the windshield by the headliner and routed the wire the same way. Both have been good ways for me. See the cups and mount that I'm talking about below.
888.280.7799 | 6am - 5pm PST
Old Dec 11, 2015 | 05:37 AM
qolor's Avatar
qolor
My Passport Max fits up in my field of view at the top right next to the rear view mirror. I stick my suction cup on real good, and then I slide the detector onto the mount. My mount has "notches" in it. I slide it on til the back unit touches the wind screen and then let it click into place. It doesnt need to be seated all the way back on the suction cup mount (unless older models dont have this adjustability on the mount?) and then I hardwired it into one of my map light switches (since they dont get used) and if I leave it on the map light circuit turns off when I lock the car. (05 MCS with the E46 style key, 3 button)
Hoped it helped.
Old Dec 11, 2015 | 12:59 PM
BRebels's Avatar
BRebels
Still too much rake when I try to attach to the top of the windshield.
The search continues
Old Dec 11, 2015 | 01:18 PM
qolor's Avatar
qolor
You can't adjust the angle by sliding the detector in and out of the suction cup mount? You can always bend the mount where it slides into the detector (outside of the detector or you will snap the plastic)
I would try bending it to the perfect angle or aligning it on the clip. If you need me to take a pic of what I mean by adjusting on the clip lemme know.
Old Dec 11, 2015 | 04:05 PM
BRebels's Avatar
BRebels
The mount for the 8500 does slide but it has to lock into place.
Old Dec 11, 2015 | 06:23 PM
bavmotors's Avatar
bavmotors
There's always the escort supercup mount, that has a tilt function.
Old Dec 12, 2015 | 07:15 AM
qolor's Avatar
qolor
i tried.
Old Dec 12, 2015 | 01:57 PM
BRebels's Avatar
BRebels
Yeah I'm afraid that's my only & next option.
Found it for $30 on Amazon
Old Feb 25, 2016 | 06:07 PM
matthoef's Avatar
matthoef
Not sure if you've solved this in a manner that you wanted, but have you looked into the BlendMount ones?
https://store.blendmount.com/all-min...ors-c3175.aspx
While I personally can't attest to the fitment in a Mini, I have a friend that had one in his Vette and the fit/finish was awesome. I'll be picking one up when I finally get around to picking up a radar detector this summer.
Old Feb 26, 2016 | 08:49 AM
quikmni's Avatar
quikmni
My Escort 8500 mounted fine next to the mirror. I did bend the mount to the correct angle. I have it pressed lightly against the mirror to eliminate vibration. I can use the two individual suction cup mount or the super cup mount (currently installed). I also routed a power wire through the headline, A-Pillar, and down to fuse box.
Old May 18, 2016 | 09:56 AM
ApexinM3's Avatar
ApexinM3
I'm resurrecting an older thread but I am having the same issue: too much rake using the suction cup mount. I looked in to the BlendMount, which looks awesome, but cannot verify the fitment around the post to the mirror. /the pics show what looks like an R56 mirror (switches above the mirror) so I can't tell for certain.
Has anyone else used this mount in their R53? I'd like to use this product as it's top notch and made in the USA to boot.
Thanks!
Old May 19, 2016 | 08:45 PM
putttn's Avatar
putttn
My Valentine works well with the suction mount just to the left of the mirror. R53 and the mount had fore and aft adjustment.
Old May 20, 2016 | 05:14 AM
impala's Avatar
impala
I have the BlendMount in my 06, Not cheap but it's a perfect fit.
Old May 21, 2016 | 08:36 AM
ApexinM3's Avatar
ApexinM3
Do you remember the model number?
Old Jun 26, 2016 | 05:25 PM
MiniPlay's Avatar
MiniPlay
I got a mirror mount from radarmount.com. Installed it today, will see if I like it over the next several weeks on MTTS 2016.
Old Jun 26, 2016 | 05:47 PM
bavmotors's Avatar
bavmotors
How does it fit? Looks like a nice reasonably priced mount.
Old Jul 31, 2016 | 10:54 AM
BRebels's Avatar
BRebels
So I was going to buy the Escort Stickycup Mount:https://amzn.com/B00CYSHUG8 but decided to give this one a try:https://amzn.com/B01HBY8V80.
Going to go for a test run & let you guys know what I think.
Old Jul 31, 2016 | 02:10 PM
ZippyNH's Avatar
ZippyNH
Cravenspeed has a nice mirror mount....
But I always used a suction cup mount that came with my 8500....
Just find a nice way to run the wires, and pick your spot....
Lower for Lazer, higher for radar...
IQRaceworks
Jul 15, 2022 05:51 AM
andrewjg1994
Jan 29, 2021 07:45 PM
Wohnson89
Jun 10, 2020 04:53 AM
siriuszero
Sep 17, 2015 04:41 AM
Aug 19, 2015 12:51 PM
