Electrical Interference installing Nuvi 2798 backup camera in 2008 Cooper S
Old Dec 8, 2014 | 07:30 AM
boostednorm's Avatar
boostednorm
I initially posted in the wrong section...
I have installed this nuvi 2798 into my 2008 Mini Cooper S and the backup camera works for about 10 secs then turns off as if power was removed.
I have the camera and wireless transmitter wired to my backup lights, blue/gray -power and brown - ground. If I press the start button for a very short time then quickly move to reverse I'll be in reverse without the car running. In this mode the backup camera works fine as long as I don't start the car. When I do it lasts for about 10 secs and switches to navigation mode. It will not work again until I shut off power to the car and restart.
I've installed this same GPS with another camera in my 2001 vette and it works fine. With the vette in storage I'd hoped to use this nice 7in GPS in the Mini. My guess is there's some sort of radio interference but I have no idea what could be running at 2.4 ghz in the Cooper.
Anyone else run into this issue?
Old Dec 8, 2014 | 12:08 PM
minigen's Avatar
minigen
Thanks for your reply on my help post, I actually have the same GPS with backup camera as urs. Still need help on which is the ground wire since I saw multiple brown colored wires, I'll install it once I figured out and report back if I have the same issue.
Old Dec 8, 2014 | 01:14 PM
boostednorm
Ah, I see what you mean. Well, if you look in that cubby hole to the right and going upwards to the tail lights you'll see a bundle that has maybe 8 or so wires. That's where you'll find both blue/gray and the brown wires.
Old Dec 8, 2014 | 01:16 PM
boostednorm
I'm moved my display to within 1.5 feet of the transmitter and still have the disconnection. Then I thought it might have been my 3rd brake light pulsar but I pulled that and it had the same results. So I'm buying a DC voltage regulator,
Amazon.com: DROK™ LM2596 Adjustable Voltage Regulator 4.0-40V to 1.25-37V DC Converter 36V to 24V to 12V to 5V Car Motorcycle Buck Step Down Variable Volt Power Supply with Red Voltmeter Display: Electronics Amazon.com: DROK™ LM2596 Adjustable Voltage Regulator 4.0-40V to 1.25-37V DC Converter 36V to 24V to 12V to 5V Car Motorcycle Buck Step Down Variable Volt Power Supply with Red Voltmeter Display: Electronics
and seeing if that helps.
Old Dec 10, 2014 | 04:36 PM
boostednorm
That did the trick. Works like a charm now. ��
Old Dec 12, 2014 | 04:43 PM
minigen's Avatar
minigen
Glad it worked out for ya, I'm still waiting for the weather to do my install. Storm over here in NorCal. No garage, lol
Old Jan 16, 2015 | 08:35 PM
minigen's Avatar
minigen
I just got the chance to install my backup camera, and same thing happened to me. I'm going to get the DC voltage regulator as u did. How does it working for u so far? I'm not any good at electronic stuff, wondering if u need to setup the regulator and how? thanks a lot.
emulajavi
Dec 24, 2018 09:15 AM
Benibiker
12
Aug 2, 2016 12:46 PM
massmini03
Aug 12, 2015 11:19 AM
jeremy_reyes94
Aug 12, 2015 10:56 AM
