Electrical Mini indy mechanic and ISTA programming issues
Old Nov 11, 2013 | 09:18 AM
User 31621's Avatar
User 31621
n
Old Jan 12, 2014 | 08:08 PM
joylove's Avatar
joylove
It's not a stolen interface, it uses the ISO standard K line transceiver. The BMW software (DIS or INPA+NCS) however is not legit. PA Soft is legit. Navcoder is legit.
Old Jan 12, 2014 | 11:29 PM
Deluded's Avatar
Deluded
joylove is correct, most BMW diagnosis software floating on the internet are pirated and/or cracked in some form. They still work, mind you, so if legality is an issue, you'll need to get a J2534 programmer and a subscription from the BMW TIS.
That still won't fix your problem, so the solution is to somehow source a old (and legit) copy of INPA/DIS/NCS EXPERT, but it's unlikely.
You can buy a BMW OBD II connector on ebay -- most will include some form of INPA/NCS EXPERT/SSS/PROGMAN....read the description carefully. Some are K-can only, which means they can connect to 2007 and below ONLY, some are D-can, which can connect from 2008-2013 vehicles.
These are your options, or find someone who has the appropriate adapter and software and buy them a coffee or a pizza.
I'd do it for a pizza, but I'm in SoCal.
Pennengr
Oct 13, 2015 11:42 AM
mikes603
Sep 11, 2015 11:00 AM
Bradg33
Apr 21, 2013 09:53 PM
