Electrical Heated seats module/wiring
Old Dec 8, 2011 | 08:59 AM
Brad Bedell's Avatar
Brad Bedell
I'm adding OEM heated seats to my Car.
Does anyone happen to have a photo of the bottom of their seat that shows the OEM 8 pin connector and heated seat module?
There isn't an 8 pin under my seat, but might be one tucked under the carpet. (I've not dug in to it yet) I looked on the WDS site, but when I clicked on the connector x013709, it went to a 404 error.
Ideally, I'd like to make sure I have ALL the parts ready for when I tear into the car. Dealers don't do this on a regular basis, so Parts guy at the dealer isn't sure what all I *need* and doesn't want me to end up with a bunch of spare parts.
Ac panel/circuits are in route, modules, heat pads are in route. Still working on programming options, but it's being considered.
Old Dec 12, 2011 | 02:03 PM
bearheroes's Avatar
bearheroes
look for connector x275
Old Dec 12, 2011 | 07:05 PM
Brad Bedell
Thanks! Looks pretty straight forward. I received the modules today, I'll yank a seat and look around for a connector. However, I suspect I'll be buying a harness. I'm planning on taking lots of photos when the time comes to install this stuff.
If someone had a photo that caught the view when installing an amp or something. I'd still feel more warm and fuzzy if I could *see* what I'm getting into, but I'll figure it out either way.
Old Dec 12, 2011 | 10:37 PM
bearheroes's Avatar
bearheroes
you can buy the connectors and the pins.the harness is very expensive.so buy the connectors and use your cables.check the part numbers here http://www.realoem.com/bmw/showparts...g=25&lang=enUS
Old Dec 13, 2011 | 06:36 AM
Brad Bedell
I ordered #3 on this page: http://www.realoem.com/bmw/showparts...g=10&lang=enUS
I might order the connector/pins if that doesn't work out or it's not already under my seat. Honestly, it'd have been quicker to yank the seat out than speculate on the WWW... I need to step away from the computer!
Old Dec 13, 2011 | 06:41 AM
bearheroes's Avatar
bearheroes
it is cheap.so it is no problem buying it.However i prefer doing these myself!
Old Dec 13, 2011 | 08:25 AM
Brad Bedell
Connectors and pins are cheap, so is the harness bit at $22. I'm into the heated seats about $600 for OEM retrofit. $5.00 for pins/connectors or $22.00 really isn't of concern at this point. I prefer to not have to buy the correct color wires to keep wiring simplified for future diagnostics. (by myself or a Mini Technician)
Cheap would have been a $150 ebay 'universal' kit, which I have to admit would have been a very decent solution as seen on the DIY page. But I've also seen dealers send a car down the road and refuse to work on them due to professional, but non-standard wiring practices.
Now, if I could only find a source for the cloth type electrical tape found in all the German cars...
Old Dec 13, 2011 | 08:57 AM
schatzy62's Avatar
schatzy62
I got it from my dealer. They gave it to me for free but i have heard of others getting a roll for $8-$10
Old Dec 13, 2011 | 09:08 AM
Brad Bedell
Thanks! Sent the parts guy an email. It's probably an odd request.
Old Jan 5, 2012 | 07:29 AM
Brad Bedell
Cloth friction or anti-friction tape is the proper term for it. 3m seems to be the best (as per norm).
OEM Heated seats are retrofitted and work. I'll do a complete write-up for the DIY section with prerequisites, problems and pitfalls that I encountered with the process.
Old Apr 22, 2012 | 06:04 PM
SODA66's Avatar
SODA66
Heated Seat fuse location - power
Brad - I see you wired heater seats up in your mini. I have a question. Prior to the install were the fuse holders (passenger compartment) labeled "heated seats" empty ie no fuse in them. . What did you have to do to the fuse box to get power to the seats. I do not have heated seats but want to use the heated seat fuse location as a power source for fog lights on my car. I am figuring using this as a source , that power would be off when the ignition is off, thereby , I would not have to turn my fogs off every time I turned the ignition off. Basic question , is there power to the heate seat fuse location from the factory.
Thnks
Old Apr 22, 2012 | 08:25 PM
Brad Bedell
Yes, I had fuses there and yes they were on. There was some programming I had to do to enable the PWM signal, but the 30amp(?) fuse was engaged when the power was on.
patsum
26
May 29, 2021 06:29 PM
molala
Oct 2, 2015 01:53 PM
KristaMcCoy
Sep 12, 2015 05:37 PM
Norton70
Sep 7, 2015 05:06 PM
Sep 3, 2015 01:45 PM
