Electrical Nonsense indicators
Old Aug 1, 2011 | 02:32 PM
A1CMini's Avatar
A1CMini
Nonsense indicators
Hello NAM, I bought my used 2005 mini cooper in January and have not had to do anything to it except change the oil, tires and put windshield washer fluid in it. Overall, I love it.
This morning, however, I was coming home from a camping trip not very far away and the cruise control would not work, the indicator just blinked then went out. I thought it odd but was hoping restarting the car would make it go away. before I got home the emergency brake light flashed on for a minute then went out again.
I picked my mother up to go down the road for breakfast, but when I restarted the car the engine light, ABS light, e-brake light, DSC light and tire pressure light were all on. It drives fine and all of the windows/lights are working. The speedometer also stopped working, as well as the MPG reading. The brakes work fine, the e-brake wasn't on, the tire pressure is where it should be, and I definitely wasn't losing control or slipping/slidding (to make the DSC light go on).
I'm thinking it has to be an electrical problem, a loose plug or corroded ground... If anyone could give me guidance on a location to check for plugs or other simple wiring issues that could be at fault, I would greatly appreciate it. Or if you think it could be something more serious, I would appreciate the help even more!
In addition, I drove the car to an auto part store and they used the fault code reader on it, it came up with two codes (he didn't tell me the codes, but I could always go back and get them) that both said it was a general error.
Old Aug 1, 2011 | 03:37 PM
ScottRiqui's Avatar
ScottRiqui
The ABS/DSC/Tire Pressure trifecta is a sign that one of your wheel-speed sensors has failed or is about to fail (all three systems rely on wheel speed measurements to function). It's a fairly common occurence with the first-gen MINI.
Old Aug 1, 2011 | 03:52 PM
Capt_bj's Avatar
Capt_bj
is the battery original?
I replace my bat's at 5 years .... period!
These cars do not like weak/failing batteries . .
Old Aug 1, 2011 | 05:46 PM
A1CMini's Avatar
A1CMini
Capt_bj: I'm not sure if the battery is the original, but I tested it and it says that it's still good.
I did, however, find a blown ABS fuse. I changed it and started the car to check if the fuse would blow again, it didn't. All of the same indicator lights are still on though. My father said I may have to have the computer reset before the lights reset. I'm about to look into how to reset the computer, one person recommended unplugging the battery for a few minutes, but I think I read elsewhere that the computers have internal batteries.
Old Aug 14, 2011 | 05:11 AM
A1CMini's Avatar
A1CMini
So, I've been poking around under the hood... which probably isn't good since I'm not a mechanic, but I did find something.. a blown ABS fuse. I replaced it and checked it a few days later, blown again.
Does anyone know what could be causing the abs fuse to be blowing?
Old Aug 14, 2011 | 08:19 AM
36rodder's Avatar
36rodder
From: I live in Webster, NY (just east of Rochester)
Not sure if this applies to a MINI but I experienced a similar situation with my wife's '08 Buick Enclave. Same symptoms, no cruise, stability control, ABS lights. It took me awhile to figure it out. I checked fluid, brakes, rotors etc. and found nothing wrong. I finally figured out that it was low master cylinder fluid level. The level looked fine but was just low enough (from brake pad wear) to trip a sensor which set off the tri-fecta. You would think with all the indicators they would just give you a low brake fluid warning like they do with windshield washer fluid. SO.. try topping of your brake fluid and see if your symptoms go away.
Alpha Motoring
Nov 10, 2015 07:08 AM
Alpha Motoring
Oct 1, 2015 10:30 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
MiniSMan
Sep 29, 2015 06:38 PM
EVMini
Sep 28, 2015 10:20 AM
