Electrical Torque app for Android compatibility and settings
Old Jun 27, 2011 | 04:41 PM
  #26
kat1689's Avatar
kat1689
a cheap $40 chinese version of the adapater from Amazon (Xitech XL7)
I have this one too, it seems to give me info most of the time but torque always says faulty obd device or something like that, has anyone else seen that message at the bottom of the app?
Old Jun 28, 2011 | 11:01 AM
  #27
NightFlyR's Avatar
NightFlyR
I guess I am lucky, no issues with the wireless adaptor I have from amazon, I also routed a power wire under the dash and up to the phone with the holder on the right side of my speedo, ( I have the nav) No problems reading it and it charges as I drive with no wires in the way.
Old Jun 28, 2011 | 11:13 AM
  #28
silhouette88's Avatar
silhouette88
I've seen it with the Amazon cheapie I got, but never with the Kiwi. I think NightFlyR got one of the 10% that work. If you're ever in Vegas let me know, I definitely could use your luck.
Old Jun 28, 2011 | 11:20 AM
  #29
NightFlyR's Avatar
NightFlyR
Well lets just say I have had almost all good luck with anything from amazon, except 1 camera battery i purchased, that 1 exploded in my bedroom and almost caused a fire, they did however replace and compensate me for it. But other then that it has been good
Old Jun 28, 2011 | 11:26 AM
  #30
silhouette88
"Burn-em upus bedroomus"
Old Jul 6, 2011 | 08:13 PM
  #31
cenobyt's Avatar
cenobyt
I purchased the cheapo ebay adapter (29.99 + free shipping) about two weeks ago. Received it within 3 days (they're based in NYC). It works flawlessly with the Torque app. No issues at all.
adapter: http://goo.gl/Yttma
Old Dec 9, 2011 | 06:55 AM
  #32
peter314's Avatar
peter314
Joining the club a little late but not a problem.
I am absolutely in love with this thing; MINI Connected just released an update to the iOS app and it doesn't even do 1/4th of the things that Torque does.
I bought this bluetooth adapter from Amazon, The Soliport ELM 327 and have had 0 problems with it and my EVO 4G.
www.amazon.com/Soliport-Bluetooth-Diagnostic-Scanner-wireless/dp/B004KL0I9I/ref=sr_1_1?ie=UTF8&qid=1323440800&sr=8-1
I also bought the 2 ft 90 degree cable and have it tucked up under the dash with some velcro, Again it works flawlessly. Loving it!
I recommend this set up because for a total of ($5 app + $22 adapter +$10 cable) $37 you have a complete setup
Old Jan 24, 2012 | 10:43 AM
  #33
Neitherfanboy's Avatar
Neitherfanboy
I've done a couple of searches but have not found an answer to my issue. I bought the ELM 327 from Amazon, paid $20.99 for it (what a deal). But when I plug it into the ODBII under the dash on my 09 MCS, none of the lights on the adapter light up, and my phone does not see the adapter when scanning for Bluetooth devices.
Does the ODBII in the Mini need to be "turned on" by some method, or should this adapter work as soon as its plugged in and I have a dud?
Old Jan 24, 2012 | 11:16 AM
  #34
TSur's Avatar
TSur
The ODBII port has power even without the key in. So it sounds like you have a "dud." I have read a lot of people complaining about the cheap adaptors. If you got it on Amazon they will refund you and not charge you to ship it back.
Only thing I would check is that the device you have doesn't have a power switch on it. I am using a wifi adaptor with my iPhone and it has a little power switch on it.
Old Jan 24, 2012 | 11:22 AM
  #35
Neitherfanboy
I was afraid of that. No power switch on the adapter. I will send it back to Amazon and look for the Kiwi adapter. Thanks!
Old Jan 25, 2012 | 04:54 AM
  #36
schatzy62's Avatar
schatzy62
Dont buy a cheap adapter. Even if it does work not all functions of Torque will work. Buy a good quality one and you will have not problems. Dont cheap our or you will regret it.
READ what the app creator says about adapters on the Torque website hie VERY SPECIFIC about them.
Old Feb 3, 2012 | 12:56 PM
  #37
SooperCuperErik's Avatar
SooperCuperErik
I'm using the $22 version and it works perfectly and provides all data.
Key to when it doesn't connect is going into the menu of the app and selecting the bluetooth device to use, after you've paired the device to your droid. I have a feeling many people just plug it in, realize it doesn't automatically connect after pairing, then say its a dud and return it. I was stumped for a good 10 minutes, but then found this in the menu and since its been selected it works everytime I plug it in now.
I only use it for data logging, as my SGII gives me IATs and AFRs, etc, and my boost gauge provides a quick vacuum update vs the lagged SGII. So for the capability, it was worth the chance at the $22 route vs the 60 or 80$ route, however much it costs.
Old Aug 9, 2012 | 02:51 PM
  #38
BLU-BY-U's Avatar
BLU-BY-U
I got the Super mini Bluetooth from China. It works great and is half the size of the mini and a 1/4 the size of the Soliport, plus it was $13.99 on Amazon with free shipping. Is there a list of the PIDs for things like the oil pressure and other things to monitor that aren't in Torque? Or is that the difference from the free version to the paid version?
Old Nov 11, 2013 | 08:55 PM
  #39
jonprivate's Avatar
jonprivate
I bought this bluetooth sending unit for my Mini and the Torque Pro app for the Android. I love it. It told me of a code that was getting thrown, about camshaft being over retarded or something like that. Come to find out when I searched the code it needed an oil change and clean up. So I used the Sea Foam on the car to clean it up and that threw all sorts of codes and misfires. I used the app to clear the codes and nothing has come back since, and it's been 2 weeks so far now.
I also was monitoring the Intake temp and air temp, and there was a very huge difference, so this made me work on the intake to insulate it from the heat from the engine, and i got it to drop 25-30 degrees which means more HP and MPG. So the bluetooth module and Torque app have already paid for them self. Is anyone else using this product, if so what are you using it for?
Old Dec 19, 2013 | 12:39 AM
  #40
Redrek43's Avatar
Redrek43
The set up
My set up
Attached Thumbnails Torque app for Android compatibility and settings-image.jpg
Old Dec 19, 2013 | 12:52 PM
  #41
BLU-BY-U's Avatar
BLU-BY-U
Originally Posted by Redrek43
My set up
Nice, what background and Dials are those?
Old Jan 5, 2014 | 06:39 PM
  #42
gregsmini's Avatar
gregsmini
I've had a Galaxy III with the paid Torque app and the Kiwi Bluetooth adapter for about three weeks. I'm running temperature, vacuum/boost, and a few other gauges. I can't see oil temperature or oil pressure as an available sensor to use with the app. As I said I'm new to this so can anyone tell me if there is a way to get either one of these?
Thanks Greg
Old May 13, 2014 | 11:44 AM
  #43
repollo's Avatar
repollo
So have anyone worked on finding out the custom PIDs for the MINIs? Or at least does anybody know where to look for them?
Old Sep 29, 2014 | 06:49 AM
  #44
edwkmho's Avatar
edwkmho
I have just gotten a Kiwi2Bluetooth and paid version of Torque, but i could not get it to read the boost correctly. When i set it to display BAR instead of PSI, only positive value, nothing from negative value at all.
Could any share their Torque vehicle setting and unit setting.
I have a 2009 fJCW EU version.
Old Oct 2, 2014 | 02:53 PM
  #45
luigi90210's Avatar
luigi90210
just go into the settings and change the readout from bar to psi, also our cars do not go into vacuum, idle is controlled by valvetronics and not the throttle plate
also this is off topic but i am seeing everyone is spending way too much money on these adapters, i spent $10 on an elm327 slim obd2 to bluetooth adapter, its the recommended adapter for torque pro and elm327 is name brand
Old Oct 17, 2014 | 07:58 PM
  #46
edwkmho's Avatar
edwkmho
i did try using PSI but it gives me value as high as 35psi, which i assumed is incorrect at all. Not sure where when wrong in this. By the way does the intake manifold pressure is the same as boost?
Thanks.
Old Oct 18, 2014 | 05:06 AM
  #47
gregsmini's Avatar
gregsmini
My MINI does record both vacuum and boost. I don't know about the N18 engine but the N14 certainly does. When I'm driving and not pushing it hard, the engine is no different than a non-turbo car and, yes, I do have vacuum. When I'm hard into the accelerator and the turbo is pushing air into the intake, the gauge goes from vacuum to boost.
Old Nov 1, 2014 | 09:46 AM
  #48
edwkmho's Avatar
edwkmho
Hi Gregsmini,
Thanks for your quick respond.
Can you share what setting you have for your Torque. I have never seen vacuum in my N14 before, either using psi or bar.
By the way, my Mini is EU spec with a Hot Film Air Mass Meter.
miniuy
Oct 7, 2016 12:09 PM
Bruce/Fl
Aug 28, 2015 11:59 AM
PEterChoqu
Aug 26, 2015 08:33 AM
tag1260
Aug 24, 2015 05:52 PM
minipopkart
Aug 13, 2015 05:22 AM
