Electrical LED Resistors
Old Jan 26, 2011 | 12:52 PM
GeoffreyM's Avatar
GeoffreyM
LED Resistors
Just finished putting the resistors on my car so that all of my LED additions stop setting off the computer.
So,
-Parking lights in the front, piece of cake, follow the instructions that come with your resistors. I mounted mine with 3M SuperDuty Double stick and then nuts and bolts through the fiber board. Brown is Ground.
-License Plate, also very easy, only took one resistor for both. Mounted on top of the housing. Brown is Ground.
-Tails, More complex....took three per tail, mount three ground onto the brown line. Then one end of each resistor on each yellow wire(there are two and they are the brake/tail lights) One on the blue/silver wire that is on the far left of the harness(blinker). I mounted the resistors to the body inside the access panel of the light with self tappers and double stick and no errors anywhere!
Old Jan 26, 2011 | 03:23 PM
rkw's Avatar
rkw
What LEDs did you put in the tails, and did you compare brightness with the original bulbs? For exterior lighting, plug-and-play aftermarket LED bulbs are generally dimmer than the filament bulbs they replace.
Old Jan 26, 2011 | 04:26 PM
iwashmycar's Avatar
iwashmycar
Did you just add resistors until the warning light went away??
Old Jan 26, 2011 | 04:44 PM
GeoffreyM's Avatar
GeoffreyM
They are as bright if not brighter than the Incandescents they replaced. They also have a "cleaner" light(best I can describe it). I got them at www.superbrightleds.com (here's a plug guys how bout a discount next time!)
I have so far replaced ALL of the interior, Tails, Driving Lights, License Plate, and side markers. The Headlight Blinker got Chrome dusted amber(i think they look better). Pictures at night may not do it justice but I'll do some soon.
Old Jan 26, 2011 | 04:46 PM
GeoffreyM's Avatar
GeoffreyM
On the tails it was a pain to try to figure out what the computer wanted to have resistance and which didn't. What I described previous was after a few days of trial and error.
Old Jan 31, 2011 | 01:35 PM
Nimrandir's Avatar
Nimrandir
pics pics!! I already bought led parking light, they have a incorporate resistor...
Take some pics at night putting the camera on a tripod!!
Old Feb 6, 2011 | 10:41 AM
GeoffreyM's Avatar
GeoffreyM
Old Sep 14, 2011 | 08:18 AM
threar's Avatar
threar
I see in the NCS Expert spread sheet some entries for bulb warnings; if I applied these changes, what resistors would be required? (Perhaps this should be in the LED thread instead.)
Old Sep 14, 2011 | 09:39 AM
GeoffreyM's Avatar
GeoffreyM
If you remove the cold and warm check you don't need resistors. The other option is to use the 45 light towers and then you don't have to do either.
Oct 1, 2015 12:13 PM
Sep 30, 2015 11:39 AM
Sep 30, 2015 11:38 AM
Sep 30, 2015 11:25 AM
Sep 29, 2015 12:11 PM
