Electrical Factory driving light question...
Old Nov 18, 2010 | 11:44 AM
Bigprfed22's Avatar
Bigprfed22
Any one know if you can re-utilize the factory driving lamp mounts with hellas?
Old Nov 30, 2010 | 09:09 AM
condor27596's Avatar
condor27596
Not sure if you already have your answer.
You will need to dremmel the grille out.
You won't be able to tell it because the lights should
conceil where you cut.
Here's a pic.
http://i214.photobucket.com/albums/c...Picture008.jpg
Notice the black line where the chrome should be. Well, you can
cut the chrome out just a bit and it will slide back on. Which I did.
My problem is that a big wind came when I was backing out and
I ran over mine.
Old Nov 30, 2010 | 09:17 AM
Bigprfed22's Avatar
Bigprfed22
I already installed, i had factory driving lamps which were pre cut but the brackets did not support the hellas, connected them to the grill and now im all good
Old Dec 1, 2010 | 05:48 AM
condor27596
That's odd.
My brackets worked great.
It was that they were too deep toward the grille that
was the problem.
I'm glad it worked out for you.
Old Dec 1, 2010 | 07:13 AM
Bigprfed22's Avatar
Bigprfed22
You had the OEM brackets?
Originally Posted by condor27596
That's odd.
was the problem.
Old Dec 2, 2010 | 05:54 AM
condor27596
I bought the kit from the mail order dealer always linked on this site.
I forget the name this second. It came with instructions, a plastic
grille (the black part) with holes for the brackets, and brackets.
I had to remove the chrome pieces and put them on the new.
It took a while. I could have just drilled out a slot on my existing
grille.
There are better much better brackets made by a NAM vendor I did
not know about them at the time. The existing grille could have been
drilled out to fit and you could never see it. Using the non OEM
brackets I would not have had to cut my plastic chrome pieces to
make them fit. Big lessons learned but I'm not making a do-over.
The non OEM foglights (those are foglights BTW, not driving lights.
I use them as DRLs, they are pointed slightly lower than my low beams)
were too deep for the OEM bracket, so I really had to cut the grille
to allow them to bolt on. You can't see it because it is behind
the lights. It took a while too. Cut, put them on, take them off, repeat.
It took me all day to do this. So $50 more and all day, for a not as
perfect solution.
They are not wired to the lights in anyway, thus, they can be used as
DRLs. (manual switch on the knee panel)
Old Dec 2, 2010 | 07:01 AM
Bigprfed22's Avatar
Bigprfed22
I Replaced my oem driving lights with the 500's, I just mounted them to the grill. I have my grill cut but you cant see the holes because of how i mounted them. ill take a pic so you can see how i did it. I also have a jcw grille as well.
Old Dec 2, 2010 | 07:21 AM
condor27596
That sounds great.
I wish I had known more/educated myself better before I started the project.
I'm glad too I'm not the only one that thought $900 for front lights
was a "bit excessive".
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
