Electrical Close Windows & Sunroof with the remote, yes you can
Old Jan 21, 2011 | 12:34 AM
  #76
Yzo's Avatar
Yzo
Originally Posted by fishbert
Well hell, I can do that by just holding the buttons on the tach.
True, but I can also do stuff like force the Infotainment computer to reboot to pickup coding changes.... plus make it spam the gong sound.
Thanks strobey. After I figured out how to default the modules the updated VO took effect. I've never had so much fun lobotomizing my car.
Old Jan 23, 2011 | 01:59 PM
  #77
cmcveay's Avatar
cmcveay
Is anyone that's got this set up running going to the Dragon? I seem to be chasing my tail in circles trying to get this set up working so I'd like to see if anyone would be willing to look over my shoulder to get it running and share some pointers.
Old Jan 23, 2011 | 02:01 PM
  #78
TheCheatOSX's Avatar
TheCheatOSX
I would be very interested in this as well!
Old Jan 23, 2011 | 03:32 PM
  #79
strobeyprobey's Avatar
strobeyprobey
More fun! Today I got the one touch sunroof software change made, I tried all four variations to see if I could get it to shut entirely by it self, but it stops at the vent position, so it is still two presses to get it to close or open fully. But a heck of a lot better!
Plus I did the change to the IHKA to get the AC not to engage when hitting the Auto button. Awesome!
Have you been able to read the ULF with NCS? Mine doesn't.
Also, since you reported more success with INPA, I did figure out how to update INPA with the newer data files and I can access a lot more with it now. But DIS v57 is still WAY better. And I updated both NCS and INPA with the ISTA/P v40 data files.
Old Jan 23, 2011 | 05:28 PM
  #80
toolazyforalogin's Avatar
toolazyforalogin
hey strobeyprobey for the one touch sunroof, which of the 4 options did you set? IIRC one of them was already set to aktiv.
Old Jan 23, 2011 | 06:30 PM
  #81
fishbert's Avatar
fishbert
Look back at post #59.
Old Jan 23, 2011 | 06:37 PM
  #82
toolazyforalogin
fishbert - I read that post - you say
In the SHD module, there are 4 settings: SCHIEBEHEBEDACH_TIPP_HEB, _SENK, _AUF, and _ZU (for open, close, tilt up, and tilt down functions… not necessarily in that order). One of them (for tilt open) is 'aktiv' by default.
Are you saying all 4 need to be set to aktiv? - I'm just looking for one touch open and close - I realize strobeyprobey said you can't do a one touch close - you have to "close close"
If you could elaborate a little further that would be helpful to me. thanks.
Old Jan 23, 2011 | 06:48 PM
  #83
fishbert's Avatar
fishbert
The 4 options are for…
1) tilt open
2) slide open
3) slide closed
4) tilt closed
Right now, if you go to your MINI and tap the switch, it will one-touch tilt open. That's the one that's already set active.
But if you want it to slide the rest of the way open one-touch, you need to activate one of the other 3 options. And to reverse the process one-touch, you need to activate the other two.
Now, when you have all 4 activated, if you hit the switch, it will tilt open just like it does now. But if you hit it again, it will then slide the rest of the way open. So, if you want it open all the way, it's a 2-touch process. Same goes for closing; one touch will go from open to tilt, then another to close from tilt.
Old Jan 23, 2011 | 07:14 PM
  #84
strobeyprobey
I set them all active.
So I did test each one. If any of the four were not active, then that particular movement became non-one touch. So if I had the 'shut to vent' not active, then sunroof acts just like it does from the the factory: you need to hold the switch to get it to shut to the vent position. Then I could press it again (to the second detent) and get it to shut all the way.
Old Jan 23, 2011 | 07:42 PM
  #85
toolazyforalogin
thank you to you both. I would say that the only features I really wanted to get working are the:
KOMFORTSCHLIESSUNG_FB in the CAS
DIG_SPEED_PERMANENT in the KOMBI
and now the
SCHIEBEHEBEDACH_TIPP_HEB, _SENK, _AUF in the SHD
realistically we should get a sticky thread going with just the working commands and the modules they are located.
Old Feb 4, 2011 | 07:00 PM
  #86
asha's Avatar
asha
Will this work on R53? Or only on 2nd gen?
EDIT: just looked into the extracted files. Looks like R53 can use the R50
Old Feb 7, 2011 | 08:00 AM
  #87
strobeyprobey
I am not sure what options you will have available as I never looked into the module files. NCS Expert will work as long as you have the correct interface. I think the D-CAN cable will work, but it would be best to check the list of supported car models.
Old Feb 7, 2011 | 08:03 AM
  #88
GeoffreyM's Avatar
GeoffreyM
I'm ready to go, software, cable and all, but I have a R60. Anyone have daten files that include it yet?
Old Feb 7, 2011 | 08:10 AM
  #89
strobeyprobey
Yeah the R60 has been included for quite awhile, the R58 and R59 is already being included in the Daten files. I would recommend going over to the other forum and grabbing the ISTA/P v40 as well. You will still select R56 for the chassis model.
Old Feb 7, 2011 | 08:12 AM
  #90
GeoffreyM's Avatar
GeoffreyM
Thanks, but which forum are you referring to?
NEVERMIND
I see you over on bimmerforums too.
Thanks.
Old Feb 7, 2011 | 08:17 AM
  #91
strobeyprobey
The Bimmerforums diagnostic software section. There is a thread with the links to the v40 package. FYI for anyone that has updated, I have run into a couple of issues using the v40 data, I have had a few improvements and access to modules I did not have before, but I also had my FRM no longer communicate! So I had to go back to an older version of files just for the FRM to get it to work again.
Old Feb 7, 2011 | 06:09 PM
  #92
fixman2k's Avatar
fixman2k
Hello - quite the Mini u have - I'm just curious, did you get the "Pandora Radio" add on to your Mini?
Old Feb 7, 2011 | 09:57 PM
  #93
spinned's Avatar
spinned
It's time to update the first page of the forum. I am having trouble getting through 4 pages of this. Is there an easy fix for this or do you still have to buy cables and gadgets and figure out software codes to install this?
Old Feb 28, 2011 | 05:07 PM
  #94
GTECKO's Avatar
GTECKO
I agree ... I am all new to this website however I have been following many threads as some of my concerns or wonders were already asked by ppl.
I decided to join this community as I think this is the most diverse website for Minis.
Iam really interested in the mods talked about in those treads however like Spinned mentioned, I am getting a bit lost in 4 pages of instructions ... I managed to get the downloads done, got the cable, got the software to read the car, however Iam lost when it comes the step to the "coding" done ...
Would it be possible to do a "new" write up ?
thanks
Old Feb 28, 2011 | 06:48 PM
  #95
BBoshart's Avatar
BBoshart
Four pages isn't that much! Have you been following the Alta AccessPort thread!? Now that is hard to get through. Anyway, the first page lists all you need to know.
This website (http://forums.bimmerforums.com/forum....php?t=1483234) was listed and has everything you need to know about coding. I've been able to program auto sunroof, auto A/C off, permanent digital speedo, fob comfort closing, and a lot more. And I'm not horribly computer literate.
Old Feb 28, 2011 | 07:37 PM
  #96
GeoffreyM's Avatar
GeoffreyM
Still looking for the v40 daten files. As you can tell, my concentration has been elsewhere, but it's time to start coding, but I would rather not mess with stuff without them. Any help? I've been prowling the bimmer forum, but I can get them download. Thanks.
Old Mar 1, 2011 | 09:07 AM
  #97
strobeyprobey
To get the coding done, you will need to follow the steps in the NCS Dummy thread. To get the Trace file output of the module you choose, then modify the settings you want in the .man file and write.
You probably don't need the v40 files, the v34 ones I linked to will probably get most things done for you. v38 should also be floating around as well.
I would like to create at a step by step process of making the changes, but I just don't have the time at the moment.
Old Mar 1, 2011 | 10:38 AM
  #98
moondawg14's Avatar
moondawg14
My cable from ecutool.com showed up last night. It might be the weekend before I get any free time to fire it up and see what I can get done.
Old Mar 1, 2011 | 11:24 AM
  #99
robspec's Avatar
robspec
for the life of me i cant get it set up on my laptop,anyone local to los angeles got this thing working willing to help out?
Old Mar 1, 2011 | 12:48 PM
  #100
GeoffreyM's Avatar
GeoffreyM
Getting Blue screen and PAGE_FAULT_IN_NONPAGED_AREA message and then a restart whenever I start up NCSExpert. Any ideas what I did wrong?
