Electrical HID Fog lights
Old Jun 7, 2010 | 10:54 AM
DNadar's Avatar
DNadar
HID Fog lights
Do HID's in the foglights throw a bulb out code?
Old Jun 7, 2010 | 06:30 PM
mamut's Avatar
mamut
yes. you can buy bulb out eliminators from ddmtuning.com that will do the trick.
Old Jun 10, 2010 | 11:15 AM
DNadar's Avatar
DNadar
Are you 100% sure? I don't want to order them then not need them.
Old Jun 10, 2010 | 03:35 PM
mamut's Avatar
mamut
yessir...otherwise you'll get flickering problems or they wont turn on at all. you can also hard wire a resistor in the harness but the eliminator is better imo, its plug and play
Old Jun 10, 2010 | 11:07 PM
DNadar's Avatar
DNadar
I'm guessing you've learned the hard way?
Old Jun 10, 2010 | 11:49 PM
10Zero's Avatar
10Zero
Are we talking about parking lights or fogs? LEDs in the parking lights I can see this happening, but a simple change of H8 bulbs for the fogs shouldn't cause a problem...if we're actually talking about the fogs (front). I personally run Nokya 2500k Hyper Yellows, no problems here.
Old Jun 11, 2010 | 01:29 AM
Davidoyo's Avatar
Davidoyo
Does ddm tuning make a bulb out eliminator for the city lights(eyelids)?
Old Jun 11, 2010 | 04:16 PM
mamut's Avatar
mamut
yep, worked fine for a couple of hours and then started to flicker like crazy. HID's are the way to go, imo, if you dont have oem xenons.
we are talking about putting aftermarket xenons into the foglight housing. Regular bulbs wont cause a problem because of the resistor in the bulb, but HID bulbs will because they are gas powered(resulting in a bulb out warning)
do you want to put hid's or led's in there?
Old Jun 11, 2010 | 06:16 PM
10Zero's Avatar
10Zero
Gotcha, my bad. Didn't know they make a xenon setup for the fogs.
Old Jun 11, 2010 | 06:34 PM
mamut's Avatar
mamut
Aftermarket hid's are universal. You can put then in housings ranging fom foglights and headlights to flashlights.
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
Aug 19, 2015 12:51 PM
AZN Optics
Aug 16, 2015 11:52 PM
