Electrical Who has H13 HID KIT Installed?
They get warm but you are at only half the design wattage so they should be fine. Only one is on at a time so you can mount them together and it further increases capacity. Mine have been hanging in the air (not mounted to metal) for 2 years so far, no problems, no discoloration etc. Just keep them away from plastic. But for reference at least on my car they did not melt the electrical tape or the zip ties that I was using to hold them on. I cant explain the high beam problem so it sounds like maybe you had a defective harness?
Let us know about the non resistor type. Post a pic when you get it. There was an older design that did not use resistors and was powered by the headlight sockets. I had that one for a few moments but it grenaded on startup. JCarlos914 seemed to have the only working version of that one but it finally went out on him. If it is the same one maybe you will have better luck or maybe it is a different design. Post a pick when you get it and let us know how it goes 07turbomini.
Sounds like we have one thumbs up and one thumbs down for this new ebay resistor harness.
HID Kit update
I just purchased a 2013 Mini a few days ago.
I ran across this thread after unsuccessfully trying to install an HID Kit from DDM Tuning. I tried the 35 watts and 55 watts versions, tried the code /error eliminators, adding a relay directly to the battery and even reversing polarity.
After returning my kits to DDM Tuning the clerk referred me to HID Masters in Huntington Beach in the neighboring plaza.
The guy Misha was very knowledge had the right KIT.
He installed it in 20 mins flat and it now it works perfectly.
Just wanted to share this info in case anybody located in the O.C. or L.A. area is interested in installing HIDs to their non-Xenon headlights.
Cheers,
CONTACT INFO:
HIDMASTERS
HIDmasters
5482 Oceanus Drive Suite B Huntington Beach,
CA 92649
Hours of Operation: Monday-Saturday 12:00-7:00 contact@HIDmasters.com
support@HIDmasters.com
Telephone: 714.655.3798
http://www.hidmasters.com
Cheers,
CONTACT INFO:
HIDMASTERS
HIDmasters
CA 92649
Sounds like a shill. Easiest method to get rid of bulb errors is with NCS expert. My 2 cents.
[QUOTE=boxcar racer;3760646]I just purchased a 2013 Mini a few days ago.
Cheers,
CONTACT INFO:
HIDMASTERS
HIDmasters
CA 92649
[URL="[/QUOTE]
Cheers,
CONTACT INFO:
HIDMASTERS
HIDmasters
CA 92649
[URL="[/QUOTE]
Was anyone getting a weird, 6-7 flickering type of action when starting the car? I get it everytime at startup. Calling Retrofit source and those guys tomorrow mentioned above.
I also get a weird flicker on my driver side bulb when my projectors are on.
Thanks(I have a retrofit custom projectors).
This is the part that irks me, save energy with a 35W xenon over the 55W halogen then have to add ~25W of resistance to get the bulb out warning turned off.
I just ordered a kit with an OPT7 bi xenon setup and they ( in Calif ) tell me they will send whatever it takes to make it work, relay or cancelling adapter which seems to be using caps instead of resistors , so I will see and report back. I just spent $800 plus $100 programming for the OEM kit on my car so I'm gonna try the cheaper route on the wifes MINI and see how it goes, just can not afford another $900 hit.
Success finally guys
! HID bulbouts are all gone. The problem turned out to be a splice that had backed out. The 6 ohm resistors on both high and low beam would have worked the first time if I did a better job with the splice
OK the final run down on the H13 connector the center is ground, the outer 2 wires are for high and low beam. You splice a 6 ohm resistor between the two outer wires and ground, either the center conductor or chassis ground works just fine. To find the right kind of resistor, just search "6 ohm 50 watt resistor" on ebay and you will get pages of kits (Gold Aluminum heatsink, 6 ohm 50 watt with pigtails already soldered on and 4 splices), $12.99 is about average for 2 resistors shipped, you will need 4. Make sure your splices are all the way down and the wire did not back out. Also check your work (learn from my mistake!), on low beam one set will get hot and on high beam the other set should get hot. That's it problem solved
.OK the final run down on the H13 connector the center is ground, the outer 2 wires are for high and low beam. You splice a 6 ohm resistor between the two outer wires and ground, either the center conductor or chassis ground works just fine. To find the right kind of resistor, just search "6 ohm 50 watt resistor" on ebay and you will get pages of kits (Gold Aluminum heatsink, 6 ohm 50 watt with pigtails already soldered on and 4 splices), $12.99 is about average for 2 resistors shipped, you will need 4. Make sure your splices are all the way down and the wire did not back out. Also check your work (learn from my mistake!), on low beam one set will get hot and on high beam the other set should get hot. That's it problem solved
Please let us know how it all works out, I'm interested in doing this too! :D
It is a different one. That ebay kit is a source of aggrevation for me now. I am not sure if it made it through customs so no refund yet after a month and a half now. I went back to that original kit with the relay and bulb warning. I am confident I can cancel the bulb warning by installing resistors on both H13 connectors. I just learned HID's direct may have a plug in kit that does the job for our H13 connectors. Short of this ebay is full of 6 ohm 50 watt load resistor kits just for this kind of problem and I have a couple of kits on order.
Up side is it does work well , the moving xenon bulb seems to simulate hi and lo ok and the pattern was acceptable.
They then sent capacitor type warning cancelers, no change so it will need the resistors.
So if that don't work I'll send it all back and start from scratch.
I also have been playing with my motorcycle, which should be way easier since no can bus etc but the bixenon bulb would not fit, just a tad too deep on back side for my housing, so I then tried the hi/lo that uses xenon for low and halogen for high beam, it works BUT that tiny bulb for high beam is useless EXCEPT the fact it does APPEAR to work and will be good enough to pass state inspection as it does put out light hi and lo with the halogen which has no shield around it , the xenon bulb has a shield on the bottom so most light reflect off top of housing and shines down. Work better than halogen for lo beam but I would not use the hi beams. I don't ride enough at night to worry about this set up and the headlights are on 24/7 so the 6K looks alot better in the day time.
Back to tinkering, I think I may go with aftermarket projectors for my spare set of MINI headlamps I have.
UPDATE, resistors sent are actually 8 ohm, so that's good news, less waste , only 18watts. And it's sufficient to fool car.
OK, got the double 50w 8ohm resistor pack, plugged 1 into control harness connector that runs relay and bixeneon hi lo flap, plugged 1 into other cars bulb connector that is not used , just to terminate it, ALL IS WELL, no bulb outs, hi lo work. Removed capacitors they sent and they are not needed.
SO now to cable this up and mount.
So in short , buy whatever h13 kit, don't need to be canbus as it won't work anyway, and then get a set of h13 50w 6ohm resistors, you will have 4 resistors, 1 for each hi and lo beam.
I'm keeping my canbus ballast due to warranty and higher quality material. I'll be adding wire to my resistor packs so I can find a nice place to mount them for a heat sink since they get hot.
Next project, order projectors and install in my spare headlamps I can't seem to sell.
FYI 8 Ohm resistors reach 335F , I am going to heat sink them and or try 12 Ohm and see if that will be enough of a load , at 12 Ohm it will reduce current to 1 Amp and only 12 watts , as i would like to get temps below 200F .
I have ordered thermal epoxy and some 50x50MM heat sinks. Will let you know how it goes.
The good news is everything works great, visibility is improved 200% , the nay sayers who say the factory housing with out projectors will blind oncoming traffic is greatly exagerated . These 2011 housing work good with a decent cutoff built in. I admit my chevy silverado was not that way, it did broadcast light everywhere but the MINI does not. Of cousre not as clean and nice as projectors but my total cost was less than $150 for quality 35W AC ballast with 4300K Bixenon bulbs, resistor kit, relay harness.
Compared to $900 for MINI OEM bixenon upgrade. Had I known they would have worked so well I would saved my money. I was worried about the xenon output in the factory housing as some people have commented on, but having seen them now for myself those reports are not as some feared.
if you are seeking a cheap option i went with Kensun from amazon and ordered HID's and a pair of warning cancelers.
, they came out really nice and the cancellers stopped the flickering and warning light like they should.
if you are seeking a cheap option i went with Kensun from amazon and ordered HID's and a pair of warning cancelers. Video Link: http://www.amazon.com/Computer-Warning-Canceller-Anti-Flicker/dp/B00HTOB0NG , they came out really nice and the cancellers stopped the flickering and warning light like they should.
but I did go for 6k, I recommend 5K or 6K, 6 if you'd like just a tab bit hint of blue.
I like both, but goodluck, hopefully yours comes without any problems! If you ever find a way to adjust the headlight let me know. I drive an '10 MSC w/halogen
if you are seeking a cheap option i went with Kensun from amazon and ordered HID's and a pair of warning cancelers. Amazon.com: HID Kit Computer Warning Canceller & Anti Flicker (1 Pair) - (Original Kensun Brand): Automotive , they came out really nice and the cancellers stopped the flickering and warning light like they should.
http://www.amazon.com/gp/aw/d/B00H17WOK4/ref=mp_s_a_1_2?qid=1425533296&sr=8-2&keywords=kensun+hid+kit+h13&pi=AC_SX200_QL40&dpP l=1&dpID=51ZQNC798dL&ref=plSrch
This one. But when I originally bought it, they were only 34!
It's been a while since the last post here. Hopefully someone here can offer some updated help since most of the links from the previous posts here no long work. I have a pair of OPT 7 LED E13 H13 6000k from a few years ago and just getting around to possibly installing them in my 2009 (R56) Mini Cooper S. Been looking on Amazon for an error eliminator without success. Although OPT7 don't sell the same kit anymore, they said the SERIUSLED has similar set up as the resistors they offered before. Unfortunately the Amazon reviews say they don't work on Mini R56. I'm not a mechanic and just want to buy a canbus error eliminator to bring along with my kit to the "auto stereo" shop for installation. I was wondering if anyone has any luck with an error eliminator that worked with these conversion kits. Thanks.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
squawSkiBum
Oct 2, 2015 09:21 AM
