Electrical Front fog lamp bulbs
Old Apr 18, 2011 | 09:52 PM
  #251
n1tr0's Avatar
n1tr0
Originally Posted by franklinminty
  • Reach in and find the lamp holder and turn it -- I think it's counterclockwise when viewed from the rear. It turns about 1/8 of a turn and can be a little tough to get going. If you have trouble with leverage, try coming in lower, e.g. lie down and reach up towards it.
don't suppose you have a picture of the socket ? I just put my bumper back on and bolted everything up only to find one of the little 'eyelid' parking lights out. I can get my hand in there and there's a bit of wiggle in the socket clockwise/counterclockwise, but it really feels like something's going to snap before I get it free.
I was going to just ignore it for a while, but that warning light & chime are really obnoxious.
Old Apr 19, 2011 | 04:18 AM
  #252
automan21's Avatar
automan21
U have to unplug the bulb first before turning it. There's a lol nub that blocks it from turning when plugged in
Old Apr 19, 2011 | 06:58 AM
  #253
n1tr0's Avatar
n1tr0
Freudian slip right
Thanks, that's far more elaborate than most cars, usually for the little parking bulbs, they're just friction fit/pushed in.
Old Apr 19, 2011 | 10:54 PM
  #254
krim's Avatar
krim
Originally Posted by aztec1382
i did but there is too many lights listed
Only one that doesn't seem to give the bulb out is the MachV hard wire, I haven't been following this issue recently, so there may be some new developments.
As I mentioned earlier in the thread, cheapo ebay 13-smd work for a few months, then the bulb out warning will start to show up. I've gotten used to it and basically ignore it like white noise. The 12-smd you posted will probably act the same.
Old Apr 26, 2011 | 12:45 AM
  #255
Theamc's Avatar
Theamc
Just to be sure, are the PIAA 168 or the Nokya 194 city lights giving any Bulb Out warning problems?
Old Apr 27, 2011 | 04:56 PM
  #256
krim's Avatar
krim
incandescent bulbs are fine afaik, it's the unresisted LEDs that give the warning.
Old Apr 27, 2011 | 05:46 PM
  #257
pheatton's Avatar
pheatton
Yep should not have an issue with normal incandescents.
Old Jun 1, 2011 | 09:58 PM
  #258
krim's Avatar
krim
A little warning to those wanting to changing out their eyelids with LED modules, especially the ones with the white nylon base (common on ebay).
One of my LEDs burned out after a year and a half with no spare (and constant alerts), so I put the OEM incandescent blubs back in. Well... the connection is extremely loose now, one of the bulbs fell off into the housing and I had to fish it out with a bent paper clip and 2 sided tape. The white nylon base is slightly thicker and the steel wire lead adds to the thickness.
I'm hoping the metal contacts in the connector spring back and add some tension after more time.
Old Jun 1, 2011 | 11:20 PM
  #259
n1tr0's Avatar
n1tr0
If they're stretched out/bent and couldn't hold a bulb, you're going to have to bend them back, the metal pieces aren't going to heal themselves.
Old Jun 2, 2011 | 08:27 AM
  #260
Mini2na's Avatar
Mini2na
Had the same issue. I had to replace the socket... ~$13 from dealer.
Old Jun 2, 2011 | 07:33 PM
  #261
krim's Avatar
krim
They won't heal, but they'll rebound some, they've been compressed but aren't creased. Passenger side will hold now, but it's still looser than I prefer.
Good to know it isn't like $50..
Old Aug 27, 2011 | 08:57 AM
  #262
Bodhiavo's Avatar
Bodhiavo
Has anyone with the Nokya Hyper Yellow fogs also used an upgraded wiring harness? I was looking around the web for cheaper prices and this website (http://www.racinglab.com/nohyyeprohal14.html) says that the upgraded harness can help protect against the bulb heating up too much and damaging the housing. Is this even necessary, or are our fogs already wired for this type of wattage?
Old Sep 6, 2011 | 08:22 PM
  #263
krim's Avatar
krim
i3 years, and no problems on the oem harness.
Old Sep 10, 2011 | 06:05 PM
  #264
automan21's Avatar
automan21
Just get bulbs that are 35watts
The 100watt bulbs will burn your harness or mount.
Old Sep 23, 2011 | 09:43 PM
  #265
walk0080's Avatar
walk0080
Originally Posted by ke4sfq
Got them in and installed just in time for the Dragon! The Citylights look great and are a close match to the Xeon's. The Endurance bulbs are just amazing! The Licenses plate blubls are too narrow and will not stay in the sockets. I bent them a little but it wasn't enough. I felt if I bent the tabs much more they might break. Will have to go with another solution for that.
Here is a shot of them under the Bridal Veil Falls at the Dragon this weekend.
Kevin
Florence, AL
Great pic - really like those yellow fogs.
I am trying to convince my Significant Other to go with Hoen white city lights and the Hoen yellow fogs for our JCW. I figure if she doesn't like the yellow fogs, I won't turn them on when she is in the car!
EDIT: I was checking out hoen's website and I see they have this pic posted.
Old Sep 26, 2011 | 02:54 PM
  #266
walk0080's Avatar
walk0080
Finally, I'm all done.
Stealth indicators (front and rear), xenon match fogs, led city lights, xenon match reverse light.
What did you use for xenon match reverse lights?
Old Sep 26, 2011 | 04:03 PM
  #267
n1tr0's Avatar
n1tr0
more importantly, why ? did you run out of places to throw away money ?
Old Sep 26, 2011 | 04:14 PM
  #268
walk0080's Avatar
walk0080
I'm not planning on buying them but I am still curious what he/she used and what does it look like.
Old Oct 2, 2011 | 12:28 PM
  #269
jbourne's Avatar
jbourne
I'm more curious about the LED driving bulbs. I got a W5W from an eBay link mentioned somewhere in this thread and they're dying already :(
Can anyone recommend a good set of W5W bulbs?
Old Oct 2, 2011 | 12:31 PM
  #270
walk0080's Avatar
walk0080
I have ordered the PIAA extreme white bulbs for my city lights. Seem to be the consensus for the best colour match to the xenon headlights. I haven't seen much good news about LED W5W city lights so I stuck with regular bulbs.
Old Oct 2, 2011 | 12:40 PM
  #271
jbourne's Avatar
jbourne
I see. I wonder if I've messed up the socket withthe wider LED bulbs. where'd you source your PIAAs from?
Old Oct 2, 2011 | 02:15 PM
  #272
walk0080's Avatar
walk0080
I was going to buy at Amazon but they went out of stock. So when I ordered my winter wheel/tires from TireRack last week, I noticed they sold them also and added them to the order.
Old Oct 2, 2011 | 02:49 PM
  #273
jbourne's Avatar
jbourne
Gotcha. So "PIAA W5W extreme white" then?
Old Oct 2, 2011 | 07:17 PM
  #274
walk0080's Avatar
walk0080
Tire Rack labels them as "PIAA 168 Xtreme White". Haven't arrived yet - sure hope they look OK.
Old Oct 2, 2011 | 07:54 PM
  #275
10Zero's Avatar
10Zero
PIAA Xtreme White, excellent match to the Xenons. I tried LEDs too, but annoyed the hell out of me that they would flicker a bit when first turning them on. So I got the PIAAs, and am "Xtremely" happy.
You can get em from Amazon just like I did, and only about $17.00 shipped:
http://www.amazon.com/PIAA-Type-Xtre...4483194&sr=8-2
