Electrical R56 Retrofit OEM Bi-Xenon
#29
So can anyone give a simple yes or no on this ?
Can you take oem xenons and put into a halogen equipped car and just have the dealer do the reprogram or do you need to do wiring ??? And no , I don't care if I lose the auto leveling feature as I understand that would require wiring .
So if I'm to doing the washer feature , or the auto level feature , then can I just plug in some xenons and reprogram and be done ????
I took the xenons out of my 07 and put them into my 2013 and vice versa .
I already swapped out the washer jug and washer fluid hose but if it doesn't work I'm fine with that . I could take the Auto level stuff off the 07 too If I need to but can't imagine its easy to take the harness with it also ??
Thanks guys
Thanks guys
#30
Regarding Countryman halogen to xenon retrofit here is the thread with the DIY solution. As R56 is really similiar to R60, the general aproach is the same. There might be some changes in the wiring pins, however I really believe, that they are the same.
https://www.northamericanmotoring.co...t-upgrade.html
ryGuyMCS
10-20-2015 02:24 PM
blackie
10-02-2015 07:41 PM
