Electrical Amperage to the horn?
Old Mar 2, 2009 | 03:22 PM
donjulio's Avatar
donjulio
So much amperage is running through the horns when its activated? I bought an aftermarking horn that requires about 350milli amps
thanks
Old Mar 2, 2009 | 07:06 PM
MaxGSeeker's Avatar
MaxGSeeker
Its hard to find any power circuit that has less than at least 5 amps. Are you sure the horn only needs 350mA (0.35 amps) ? It may be that 0.35 amps is the power required to activate a relay that in turn delivers the total current to the horn. At 5 amps you could drive 14 horns that only draw 0.35 amps. I think the problem you will find if the horn is that small is 5 watts isn't loud on highway. The stock MINI horn is loud and uses a 20 amp circuit so assumming it draws at least 10 amps that would be over 140 watts of noise.
Old Mar 2, 2009 | 08:23 PM
ScottRiqui's Avatar
ScottRiqui
I agree - 350 mA sounds more like the relay turn-on current. As a comparison, the standard Bosch SPDT relay takes 160 mA to turn on.
Even small horns like the Stebel "Nautilus" need 20-25 amps of current. You wouldn't be getting that from the fuse box, though - you'd be powering the horns directly from the battery, and just use the factory horn wiring to activate the relay that comes with the horn.
Old Mar 2, 2009 | 09:56 PM
Sin MINI's Avatar
Sin MINI
Keep in mind that replacing OEM horns with aftermarket is illegal in most states. I added an extra horn for fun but wired it separately through the toggle bank.
And I agree with the others...most horns take 20-30 Amps, otherwise no one will hear them.
Old Mar 3, 2009 | 03:46 AM
donjulio's Avatar
donjulio
the horn does say it delivers 110db and thats why i bought it... lol
so then im not sure about the amp requirements then
ty for the info
Old Mar 3, 2009 | 06:05 AM
cristo's Avatar
cristo
Alliance Member
Wiring diagram on the OEM horn(s) (there are two) shows a 15 amp fuse
before the horn relay.
If you have an alarm, that's a third horn, but it's on a different circuit.
barnoun
Sep 17, 2018 05:04 PM
martinb
Oct 7, 2015 05:00 PM
one73ronin
23
Sep 22, 2015 09:56 AM
trw92a
Aug 26, 2015 01:47 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
