Electrical KBus Tap without dissassembly
Old Sep 28, 2010 | 07:29 PM
  #26
Charles Linquist's Avatar
Charles Linquist
I have an R56, a CAN interface board, and I write code for control systems. Trouble is - I can't find the "18 pin connector near the steering column" mentioned in an earlier post. Can someone give me more detail? Do I have to remove any panels?
Also, does anyone know the data rate used? I have seen people refer to 100Kbits/sec, but the standard CAN rates are 125Kbits, 250Kbits and 500Kbits/sec. Also, are standard (5V) signaling levels used?
Any help would be appreciated.
Old Sep 28, 2010 | 08:04 PM
  #27
Yeah.ThatsRice.'s Avatar
Yeah.ThatsRice.
Follow the steering column panel until you're in the pedal area. On the left side, look straight up (get your head in there). There will be a little cover that should say OBDII. That's it.
Old Sep 30, 2010 | 02:48 PM
  #28
lexakalex's Avatar
lexakalex
Charles Linquist: I wrote a small howto with pictures for KCAN bus http://code.google.com/p/carbot/wiki/CAN232attach
KCAN bus speed is 100K.
I also have some KCAN codes for my mini. http://code.google.com/p/carbot/wiki...desMiniCooperS
PS. KCAN and OBD II are 2 different buses. OBD II uses CAN/500 as a transport protocol, it is used for car diagnostics. There are standard programs to read various standard values from OBD II such as speed, RPMs, turbine pressure, etc.
KCAN uses CAN/100. It is used to control body electronics such as windows, doors, roof, etc. It also provides speed, RPMs, time, turbine pressure All console gauges use KCAN to read data. The biggest challenge is that KCAN is a closed BMW standard. One needs to reverse engineer protocol to make use of the bus.
Old Oct 4, 2010 | 04:47 PM
  #29
Charles Linquist
Thank you very much! Project for next weekend!
Old Apr 9, 2017 | 02:24 PM
  #30
Quadrant5's Avatar
Quadrant5
Originally Posted by lexakalex
Yesterday I've successfully connected CAN232 to the wires that go from tachometer.
GREEN - K_CAN_H
ORANGE/GREEN - K_CAN_L
YELLOW/RED - POWER
BROWN - GROUND
I've created a quick bash script to filter out irrelevant traffic on the bus.
I can see signals for the following buttons:
Steering wheel: Volume and next/prev track.
Windows
Blinkers
Computer button (the one on the blinker handle)
I can also send these commands and car responds.
I was not able to get codes for interior light switches. They might be on a different bus :-(
Haven't tried yet anything more complex such as speedometer / tachometer readings.
Hello. This is my first post on this forum as I am a new Mini owner. I know this thread is old, but it hits just what I need to know. A little extra help is all I need.
lexakalex, I have no problem following your suggestions to connect to the K-CAN bus. The part I need help with is how to physically tap into the bus wires. I tried to solder wires to the individual pins in the connector (car side, not tach side), but could not get the pin back into the connector once I was done. I know somewhere on this thread you posted a link "with pictures" and instructions. I tried to look at that but there were no pictures. If you are still following this thread, I would appreciate your help in getting over this little hurdle.
Thank you,
Quadrant5
Old Apr 9, 2017 | 03:33 PM
  #31
rkw's Avatar
rkw
Originally Posted by Quadrant5
The part I need help with is how to physically tap into the bus wires.​
There are various products available to easily tap into a wire. They are called T-Tap connectors and can be found in hardware, electrical, and automotive supply stores. I recommend Posi-Tap (https://www.posi-products.com/posiplug.html) which is more secure than the "traditional" t-tap design, available on Amazon and some automotive stores.
Old Apr 9, 2017 | 08:17 PM
  #32
Quadrant5's Avatar
Quadrant5
Thank you so much. It figures that I was trying to do things the hard way. This was just the help I was looking for. Quick reply too!
Gratefully,
Quadrant5
Doc Pain
Oct 28, 2015 07:09 PM
schwac2
Oct 17, 2015 06:03 AM
simo711
Oct 1, 2015 05:36 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
bneer
Sep 20, 2015 11:29 AM
