Electrical Help! Can't find a place inside the car to connect a ground
OK, I'm am idiot. I am hard wiring my radar detector on my 07 MCS. All went well until I tried to find a place to connect the ground. I used an add-a-fuse, hid all of the wires and then finding a place to ground it has stumped me. I ran a long ground wire temporally under the hood to make sure that it worked, and it did. I'm sure that there is probably a ground wire in the fuse panel but I have no idea which one it is. I have tried several screws under the dash but so far nothing that grounds the unit. Any help would be appreciated.
The chassis is the ground.
Find a good bolt that goes to the chassis. If you want to use a wire, the brown wires are all grounds. There are a couple of ground meccas that have lots of brown wires that connect inside a flat black thing... That then is screwed or bolted to the chassis.
Matt
Matt
I think he means bend the add-a-circuit, but I'd say find another slot - I've got two and the door fits no problem.
Finding a good ground IS an annoyance. I use one tucked up on the left side of the steering wheel, but it's a pain to get to. FWIW, good advice is when you find a good ground, add a few wires to a ring connector, then you've got a ground all ready for the next item you add.
where do u live?
There are devices that PD's use that detect your radar detector. If you get caught in a state where it is illegal, and you cant turn it off or remove it, they will impound your car as they write you a pretty hefty ticket. Just a word of warning. It doesn't matter how well you hide it. I'm in the police radar and video install/service business in case you think I'm blowing smoke.
I am aware of this. There are some states that it's best just not to have one. I have a Passport 8500 X50 which is suppose to be more resistant to detector detectors than most, but I wouldn't trust that to be true if I went to Va., for example.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
tippin
08-05-2015 08:43 AM
