Electrical HIDS on an 03 cooper
Old Feb 10, 2008 | 01:35 PM
Leetle's Avatar
Leetle
I was looking into an hid kit for my 03 mini. Have a friend that can get kits for $100 but they asked if the headlights are bixenon or not? All i know is they are the H7 bulbs correct?
The car did not come with hid's. So just a plug-n-play kit will work? Or do i need something specific for the mini?
Old Feb 23, 2008 | 02:14 PM
ZJedi945's Avatar
ZJedi945
They are NOT bixenon since you have a bulb for high beams and low beams. Yes, a plug and play kit is all you need and zip ties to hold the ballast to the headlight assembly. Yes H7's the low beams.
Old Feb 27, 2008 | 01:48 PM
RussellCory's Avatar
RussellCory
If you put HID bulbs in the non HID housing you will blind oncoming drivers at night. To do it properly you need to switch out the entire housing.
Old Feb 27, 2008 | 03:54 PM
afinley's Avatar
afinley
pretty sure its the same housing. my hid housings are stamped h7/d2r on the low beams
Old May 2, 2008 | 11:57 PM
02Doooce's Avatar
02Doooce
Any updates on this? Wondering if anyone had upgraded their H7 non Xenon to the brighter HID kit and what the results were. Additionally, curious to see/know how you installed the balasts (not much room in the hood area.
I've also thought about installing the inexpensive HID kit to the H11 bulbs in the fog lights.
Old May 3, 2008 | 03:15 PM
RussellCory
It's a really bad idea to put HID bulbs in a housing that was not designed for them. You won't get a proper or legal beam.
Old May 3, 2008 | 05:36 PM
ninjlao's Avatar
ninjlao
Ninja Mini
I installed a plug and play HID kit into my '05 halogen housing. My friend and I did a few drive-by tests (he owns an S2000) and I asked him if there was any difference between the OEM (H7s) and the HIDs while driving passed my car. He told me that glare-wise it's not a problem but since my bulbs are blue-ish it makes him want to look at my headlights.
I got my HID kit for free so I decided if it was going to be too big a bother to oncoming drivers that I would just sell it for some cash and get some Silverstars my buddy told me there's no glare. However, when I drive and look down at the road I do see some minor hot spots on the road. I think this issue has been overly exaggerated when people say that you'll blind oncoming drivers. As long as you install it right it shouldn't be a problem. The only issue that's really present is whether or not police offers will pull you over for the color of your headlights. (Which in my case has not happened once)
Old May 4, 2008 | 11:20 AM
02Doooce's Avatar
02Doooce
Thanks for the info . . . curious to know what rating bulb you are using. Sounds like its 6000 . . . I'm looking @ using the 4300. Final question, did you install the balast under the plastic headlight housing? this is where the OEM ballast is installed - if so, what are you using to hold it in its place? Thanks for your info.
Alkaidovich
Jan 30, 2021 01:35 AM
Sexual Chocolate
Mar 31, 2019 08:02 PM
phrza81
Oct 10, 2015 11:37 PM
ludedude
Aug 10, 2015 07:16 PM
