Electrical Add-a-Circuit
Old Dec 23, 2007 | 10:14 PM
poolemac's Avatar
poolemac
Add-a-Circuit
Hey Guys,
I'm looking at getting an add-a-circuit to power my radar detector and had a quick question regarding the fuses..do I want the add-a-circuit for ATO / ATC fuses or for Mini fuses?
Secondly, which fuse(s) have people had success with to tap-into in the fusebox?
TIA!
Old Dec 23, 2007 | 10:46 PM
Minidrivr's Avatar
Minidrivr
I used the ATO/ATC fuse one and put it on fuse #42. This is the fuse for the cig lighter/rear power outlet. It is the larger size fuse. The Mini has both size fuses. There is a clearance problem with the fuse box cover when using this fuse but a little bit of trimming on the inside of the cover and it fits fine.
Others have reported using fuse #32, which is the "mini fuse" size one.
Old Jan 21, 2008 | 06:36 AM
edijak's Avatar
edijak
Help please. Is fuse #42 in the fuse box inside the car or the engine compartment and where do you ground the circuit?
Old Jan 21, 2008 | 09:07 AM
Minidrivr's Avatar
Minidrivr
It's in the fuse box inside the car. I grounded the circuit with the bolt visible inside the glovebox (near the fuse box). Other have used the fuse box mount as a ground as well.
Old Jan 25, 2008 | 02:49 PM
edijak's Avatar
edijak
Fuse Panel Cover Mod
Thanks MiniDrivr. What was the nature of the panel cover modification
Old Jan 25, 2008 | 04:59 PM
Minidrivr's Avatar
Minidrivr
On the back of the cover there are pieces perpendicular to the cover. Sort of a ridge that runs around. Where it goes over that fuse I cut away that part of the cover for clearance. Hard to describe, picture might help.
Attachment 28575
Old Jan 26, 2008 | 04:23 AM
edijak's Avatar
edijak
Thanks Minidrivr. This site is awesome-you need help, you get it from total strangers. My faith is restored.
Old Jan 26, 2008 | 10:57 AM
Minidrivr's Avatar
Minidrivr
Helping is an easy thing to do..
Old Jan 26, 2008 | 02:32 PM
edijak's Avatar
edijak
Thanks to all of you in this discussion, "COOLPR" is now hardwired for radar detection. Of note, oPossum offered a great depiction of Fuse Panels and uses in his thread "Hot or Not" sometime back. When removing the fuse box cover and comparing the cover diagram to oPossums detailed explanation, I found several differences. I wound up using a Mini Add A Circuit in F23, grounding to the screw besides the glove box and all is well. The detector comes on when starting and shuts down when I am done dodging the "U know Whats" parked in the medians. As such, the LEDs in the detector do not draw the battery down if I forget to shut it off due to a small case of CRS.
Thanks to all for all the help
Old Dec 9, 2011 | 09:44 AM
tony_boy's Avatar
tony_boy
add-a circuit
hello,
just want to ask what year and model Mini you done the add-a-circuit. I have a 2007 R56 and F23 powers up my radar detector with the key off. Any suggestions on what mini-fuse I should use.
Appreciate any helpful feedback.
thanks
Tony in Texas
Old Dec 9, 2011 | 10:24 AM
John_B's Avatar
John_B
I hardwired my radar detector to the interior light circuit above the rear view mirror on my '05 MCSc. The detector comes on when the car is opened - just as the lights do, but also shuts off when the door are locked or the light timer turns the lights off...
Best thing is the wiring was only about 4" long!
Old Dec 12, 2011 | 03:24 PM
tony_boy's Avatar
tony_boy
Add-A circuit
Thanks for your help, I ended up using F32 on my 2007 MCS, a mini-fuse, works great, powers on/off w/engine.
Old Mar 7, 2019 | 07:54 PM
GeneralSpecific's Avatar
GeneralSpecific
I just thought I'd raise this thread from the dead and mention that I used F32 on my 2014 Coupe S and it works just like tony_boy said.
digitalsabre
53
Aug 11, 2019 11:00 PM
OaklandMini
How to
69
Jan 27, 2018 02:30 PM
jeffrcarlson
Electrical
Jan 26, 2015 11:38 AM
exocet
Electrical
Feb 7, 2014 06:12 PM
