Electrical Battery Relocation??
Old Oct 9, 2007 | 11:48 AM
CapWKidd's Avatar
CapWKidd
I am working on (in my mind so far) a full stereo upgrade for my 05 S, I have come to realize that I could make great use of that battery well in the back of my car for a sub enclosure ... problem is, what the heck do I do with the current battery? Could I use two smaller batteries, and place them some place else? What are the specs for the factory battery (mine is at mini for it's regular service at the moment, so I can't read the label :>) ....
I just had another thought... would it be possible/practical to make that battery well even deeper?
Old Oct 9, 2007 | 07:40 PM
Mini Tyler's Avatar
Mini Tyler
Hmmm. I am not sure about making the well deeper...but I know Helix sells a lightweight battery and battery box too that I am sure you can do something with. My ideas are relocate the battery to inside the boot, somewhere on the side, that way you will have space in that now empty battery hole for your sub. OR, go with a 1 ball exhaust and move the batter over to one of the empty can spaces and put your sub in the center (now empty) battery hole. OR! Just get a rear seat delete and fab it to hold your subs....just a few ideas. Good luck, and post some pictures when you are done!
Old Oct 10, 2007 | 02:37 PM
CapWKidd's Avatar
CapWKidd
Cut one of the pipes?! Egads! I could not do that, it would just be wrong !
Remove the seat... yes, I have thought about that... all kinds of interestin options come to mind... like using the Hertz Mille 21" sub! BOOM! hehe We'll see what I am able to do....
Old Mar 4, 2010 | 08:45 PM
MyMiniGidget's Avatar
MyMiniGidget
I realize this is a thread that is a little over two years old but im curious about what you did because i want to put in a sub in my '03 MCS but am having the same problem i need to be able to access the battery for disconnects and i need the rear seat to carry (small) people. So let me know what you did. Thanks
Old Mar 4, 2010 | 10:34 PM
Allen Coon's Avatar
Allen Coon
Hello. I am an electrician and can tell you I have read several threads containing the battery relocation. The first thing you should be calculating is the amperage to run your stereo system. And that means with the car off how long can you run it before you run the battery down to were it will not successfully start the engine? I worked in a stereo shop years ago and we were installing secondary deep cycle batteries on an isolator charging system separate from the main battery. I would recommend staying with the stock battery location and upgrade the battery to the largest capacity you can find that will fit in the stock location. If you need circuit breakers and switches mount them out side the battery area say perhaps in the compartment on the drivers side rear. This area can be arranged to house a variety of items for any good stereo system.
Be cautious of the small batteries for stereo set ups. Read the technical information on them or contact the dealer direct with question about your project. Just because it has shown to be done and some vendors offer kits does not mean it is right.
SJ-R50
Oct 28, 2015 08:39 AM
ccfirelt
Oct 18, 2015 01:02 PM
schr5530
Oct 5, 2015 08:28 AM
MiniSMan
Sep 29, 2015 06:38 PM
jennster
Sep 28, 2015 06:19 PM
