Electrical 07' Radio Harness
Old Aug 8, 2007 | 05:37 AM
mini_specter's Avatar
mini_specter
07' Radio Harness
Anyone have any luck finding a radio wiring harness for the 2007 MINI? or is the radio connection the same as last years in regards to buying a harness to plug and play into a new radio? Thanks
Old Aug 8, 2007 | 07:16 AM
STLMINI's Avatar
STLMINI
I'm no techie but how do you expect to put a new radio in an 07? With the new center stack I though it was impossible.
Old Aug 8, 2007 | 08:42 AM
mini_specter
Good point as I know the radio is now integrated as part of the speedo. I'm not exactly sure yet as I'm waiting to get my MINI. I'm thinking maybe it would be possible to yank the CD player out as it's below the speedo and fabricate some type of trim around it.
Old Aug 8, 2007 | 10:51 AM
oPossum's Avatar
oPossum
The connector on the radio is the same as the older cars.
Old Aug 12, 2007 | 03:03 PM
MotorMouth's Avatar
MotorMouth
The stock CD player is fine. Plays MP3s and shows id tags. What more do you need?
Old Aug 12, 2007 | 04:29 PM
msh441's Avatar
msh441
It wouldn't be too difficult for some manufacturer to build a harness to plug in between the stock head and harness, bypassing the stock stereo (and CD player if you so desired) while still retaining the OBC function and display. There just has to be enough demand to warrant the development and production... which is probably unlikly.
I like the front set up on the Hi-Fi pack. Nice sound imaging and clarity. Respectible bass up front. The rears however, seem a little bit muddy and when pushed at higher volumes, it amplifies these weaknesses. The rears just become muddled and overall clarity suffers.
I think the most benifical mods to the stereo would be better main speakers in the rear, and possibly a small sub in the boot.
Old Aug 12, 2007 | 10:04 PM
jrunner192's Avatar
jrunner192
If you are interested in just keeping the stock head unit and upgrading the amp/speakers check out the options at this link: http://www.newministuff.com/new/shop...roducts&cat=25
Old Aug 13, 2007 | 10:33 AM
mini_specter
Kewl..Thanks for the link. Upgrading the amp/speakers will probably be the route I'll take. I'm really not wanting to butcher up the factory layout. After thinking about it I think it's more trouble than it's worth to disable the factory head unit and tear out the OEM CD player with cutom fitting needed for the new head unit.
Old Aug 13, 2007 | 10:36 AM
Loony2N's Avatar
Loony2N
Does anyone know of a vendor with stuff like this in the US?
Old Aug 21, 2007 | 07:41 PM
darigaaz12's Avatar
darigaaz12
you can order from them, i got mine 5 days after i placed my order i think, going to install it tomorrow. I'll let you know how it goes
Old Aug 22, 2007 | 06:56 PM
a96bimmerm3's Avatar
a96bimmerm3
oPossum, do you know if the steering wheel controls for audio are like canbus or just normal wire connections? Wondering if i could hook them to my aftermarket radio. Don't want no steering wheel controls.
Old Aug 23, 2007 | 02:53 PM
darigaaz12's Avatar
darigaaz12
Ok i finally installed my new speakers in the doors and sub in the rear with the newministuff.com wiring loom and while i like the speakers better now, the sub totally lacks the deep bass i want . I didn't think the stock radio limited the low end bass that much. The install took a long time to run everything right and the outcome was only alright. I'd recomend it for anyone who want to hook up speakers through an amp but not subs (unless u dont want that deep bass anyways).
I'll be starting my new project of puttin a headunit in the glovebox or secret compartment in a few weeks when i get some cash
Old Aug 24, 2007 | 07:41 PM
FortyTwo's Avatar
FortyTwo
That's really dissapointing, but thanks for the info!
Old Aug 25, 2007 | 11:11 AM
MotorMouth's Avatar
MotorMouth
it doesn't. I get tons of bass. Have to turn it below the middle setting for bass sometimes. This is with all aftermarket speakers/amps/signal converters.
Old Aug 25, 2007 | 12:32 PM
darigaaz12's Avatar
darigaaz12
come again? what setting? I've played with my settings and can get tons of bass but not low bass it just cuts out when its about to hit.... What kind of music do you listen to? I listen to bay area rap stuff< half of it sounds about right but othe songs just lack a lot. For example E-40 - yay area, the bass is supposed to be crazy and i hear a kick pedal but no boom ok maybe a lil boom but nothin crazy lol
It seems like the frequencies are boosted in the upper bass areas or the lower ones are cut.... I've played with my crossover to try and correct this and it's a lil better but I'm putting an aftermarket radio in mine probably
hey but maybe im doin somethin completely wrong
Old Aug 25, 2007 | 12:48 PM
a96bimmerm3
I'm going to be experimenting with a rockford fosgate 3sixty for signal summing and eqing. You might want to try something like an audiocontrol epicenter to get the bass back for not too much money. I'll keep everyone updated of my results.
Old Aug 25, 2007 | 03:33 PM
darigaaz12's Avatar
darigaaz12
im think im just puttin a stereo in my secret compartment, im 99.9% sure that its standard DIN size
Old Aug 25, 2007 | 04:52 PM
MotorMouth's Avatar
MotorMouth
I'm getting a 360.2 installed on Sep. 4th. I can't wait to start playing with it. It was also the reason I broke down and purchased a Palm Pilot TX. 160+ bands of equalization/phasing/and time delays =) I'm going to be tweaking for weeks.
Old Aug 25, 2007 | 04:55 PM
MotorMouth's Avatar
MotorMouth
I'm running a 10" boston acoustics sub in a false floor powered by a rockford fosgate amp. No equalizers installed (yet). The bass is very strong. I usually have the bass setting on the head unit at +1. For some songs I may need to turn it down to -2 if I'm going to crank the volume.
The stock headunit puts out a pretty nice signal.
Old Aug 25, 2007 | 09:51 PM
darigaaz12's Avatar
darigaaz12
yea idk, I've messed with settings but its not anything like my other 3 car installs with clean low bass (cuts out no matter how I change my settings on the headunit or amp), ill keep everyone updated on my new install burnin holes throughmy pocket tho lol
Old Aug 26, 2007 | 05:43 AM
a96bimmerm3
Sweet! With any luck I should have mine within the next few weeks too. Keep us updated!!!!
Old Aug 26, 2007 | 01:31 PM
darigaaz12's Avatar
darigaaz12
aftermarket radio fits perfectly in the secret compartment
ill get some pics up in a lil bit but its sounds soooo much better now
Old Aug 26, 2007 | 01:49 PM
a96bimmerm3
I wish you wouldn't say things like that lol. Next thing you'll say the steering wheel controls work. I dont know what to do!
Old Aug 26, 2007 | 02:05 PM
darigaaz12's Avatar
darigaaz12
got some pics in my gallery now, dont know how to post them out here (nevermind im a genius lol). I have a remote with the stereo and use that instead of my stearing wheel couldnt figure out how i'd get that to work
and these pics do this no justice it looks great lol
Old Aug 28, 2007 | 04:13 PM
FortyTwo's Avatar
FortyTwo
^ Well done, sir!
