Drivetrain Digital Coolant Temp, Oil Pressure Gauges Installed w/Pics
Old Mar 5, 2004 | 10:06 PM
  #51
caddman's Avatar
caddman
Ditto!
Old Mar 6, 2004 | 05:10 AM
  #52
jlm's Avatar
jlm
this weekend I am making a drop-in replacement air-to-air intercooler with a substantially larger core. It should be an easy matter to compare heat/flow performance to stock.
Old Mar 6, 2004 | 06:54 AM
  #53
andy@ross-tech.com's Avatar
andy@ross-tech.com
jlm,
Please make two of those intercoolers. :smile:
Old Mar 6, 2004 | 07:54 AM
  #54
jlm's Avatar
jlm
this is only a prototyping project so far.
stock intercooler: 6" x 2" (12 sq" area, 12" long)
prototype has 9.1" x 2-1.4" (20-1/2 sq" area, 12" long); 70% more area
edit: just got the cores: 9" x 2" id, (18 sq", 12" long); 50% more area.
_________________
""the onus of proof is on he who asserts the positive."
Old Mar 6, 2004 | 08:56 AM
  #55
sanddan's Avatar
sanddan
Where do you make the connections for the gauge lighting? I am going to start my gauge install this weekend (boost and oil press) but haven't seen any mention of wiring for the lights. Thanks for the help.
Old Mar 6, 2004 | 09:06 AM
  #56
TonyB's Avatar
TonyB
There's a rather thick bundle of wires (about 2" diameter) in the fuse area. If memory serves correctly, I patched into red/purple. The first one found is most likely not the right one though, again, if I recall correctly. I'd check with PROMINI, or somone who has their instructions to make sure...
Old Mar 6, 2004 | 11:44 AM
  #57
BlueMCS's Avatar
BlueMCS
That is smart. Its on my list!
>>I just took mine to a machine shop. The tapped the end of the housing, installed the aeroquip fitting I gave them and I had it back in a day. I think it cost about $20.
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
Cereall
Sep 5, 2019 06:05 PM
