Drivetrain Digital Coolant Temp, Oil Pressure Gauges Installed w/Pics
Old Mar 4, 2004 | 01:29 PM
  #26
mcs22004's Avatar
mcs22004
Good point. Still, if they could even be angled up 25 degrees and slightly to the left that would be better. I think that's an OK place for the less important gauges. I'd like to put coolant temp and oil temp there and put boost and oil pressure on either side of the tach.
Old Mar 4, 2004 | 01:35 PM
  #27
andy@ross-tech.com's Avatar
andy@ross-tech.com
Now, I need to figure out a place to mount this:
Old Mar 4, 2004 | 03:06 PM
  #28
mcs22004's Avatar
mcs22004
Since you don't mind having gauges low, try in the front of the left side of the Eurotrash shelf.
Old Mar 4, 2004 | 03:23 PM
  #29
andy@ross-tech.com
I'm thinking of mounting it to the steering column in front of the cluster. I'll make a paper cutout to see if it obscures anything useful.
Old Mar 4, 2004 | 03:37 PM
  #30
MSFITOY's Avatar
MSFITOY
Hi Andy,
Hate to keep buggn you...but could you elaborate please? I'm going to replicate your install and would appreciate more detail regarding the sender mods like drilling holes into the oil filter housing...cutting into radiator hose
Thanks much,
Sid
>>The oil pressure sender is installed into a modified stock oil filter housing.
>>The coolant temperature sender is installed into a gauge adapter like the Inline Temperature Gauge adapter found here:
>>http://www.pegasusautoracing.com/pdfs/037.pdf
Old Mar 4, 2004 | 06:30 PM
  #31
andy@ross-tech.com
Check with:
http://www.promini.com/
They sell a modified oil filter housing. You screw your oil pressure sender into that housing. Then, replace the stock housing with the modified one.
As for the coolant temperature sender, check that Pegasus link. I cut the front radiator hose and installed the Tee.
The pieces I used were one-offs from a friend. But, you can get the same pieces from the sources I listed. Promini may actually have both parts, ask Al.
Old Mar 4, 2004 | 08:27 PM
  #32
caddman's Avatar
caddman
Andy how much is the intercooler guage, and Where did you get it!!!
Old Mar 4, 2004 | 08:30 PM
  #33
caddman's Avatar
caddman
I was about to use a wter temp guage and measure the water in my water to air, to monitor it, but that doesnt really tell me anything, but then again i am also putting ina a pyrometer, that should help some with tuning......
Old Mar 4, 2004 | 08:31 PM
  #34
andy@ross-tech.com
I haven't bought it yet, still shopping for a good deal. Looks like $225 is the going price:
http://www.sp-power.com/catalog/inde...Path=1432_1434
Old Mar 4, 2004 | 08:37 PM
  #35
caddman's Avatar
caddman
cool thanks....
Old Mar 5, 2004 | 06:18 AM
  #36
andy@ross-tech.com
It looks like that unit used to be made by Davtron and was considerably cheaper (~$160), but Davtron appears to no longer be in business. I asked about IAT gauges at my local muscle car shop (y'know, the kind of place that has 500 sizes of carb gaskets on the wall?) and all I got was funny looks. :???:
Old Mar 5, 2004 | 07:23 AM
  #37
ColoradoMark's Avatar
ColoradoMark
>>Check with:
I just took mine to a machine shop. The tapped the end of the housing, installed the aeroquip fitting I gave them and I had it back in a day. I think it cost about $20.
_________________
IB/W some mods
Old Mar 5, 2004 | 08:04 AM
  #38
TonyB's Avatar
TonyB
The PROMINI unit I installed a couple or so months ago gets its reading from the stock sender area (oil pressure warning light). The OEM then mounts on top of the PROMINI one...
_________________
2003 IB MCS
Old Mar 5, 2004 | 08:17 AM
  #39
CoopingInDC's Avatar
CoopingInDC
wow andy, love the guages. Enjoy!
Old Mar 5, 2004 | 10:04 AM
  #40
caddman's Avatar
caddman
I found a similar guage by autometer, it is a two channel intake temp guage, but it wont do the diffrence as well its more expensive and not digital.....
Old Mar 5, 2004 | 12:18 PM
  #41
andy@ross-tech.com
2 of these could do the trick as well for $25 each:
http://scientificsonline.com/product.asp?pn=3105400
Old Mar 5, 2004 | 02:59 PM
  #42
caddman's Avatar
caddman
that just wouldn't look as cool now would it.....
Old Mar 5, 2004 | 03:05 PM
  #43
andy@ross-tech.com
It depends if it comes with the green liquid or not.
Old Mar 5, 2004 | 03:49 PM
  #44
caddman's Avatar
caddman
True ......
Old Mar 5, 2004 | 05:05 PM
  #45
andy@ross-tech.com
Done any testing yet with the Magnehelic?
Old Mar 5, 2004 | 05:18 PM
  #46
caddman's Avatar
caddman
yes , im having fun with it this weekend.... very nice peice of equipment, much better than my old water in tube method... by the way thanks agin for lending it to me....
Old Mar 5, 2004 | 06:03 PM
  #47
jlm's Avatar
jlm
I will have the twin temp gauge here tuesday to wring out some intercooler issues. I'll install my magnehelic as well.
temp and pressure drop across the IC at last
Old Mar 5, 2004 | 06:29 PM
  #48
caddman's Avatar
caddman
which temp guage are u using jlm?
Old Mar 5, 2004 | 07:13 PM
  #49
jlm's Avatar
jlm
sp tech
Old Mar 5, 2004 | 08:30 PM
  #50
andy@ross-tech.com
Cool! Looking forward to hearing your experiences with that gauge.
