Drivetrain I need a tensioner tool!
Old Apr 22, 2007 | 04:47 AM
haji3's Avatar
haji3
OK, started to finally put on a new sc pulley, I figured I could jerryrig something for the tensioner. Nope, with out a welder I can't figure it out. Anybody renting, or sharing, mailing, have any great ideas using something from Home Depot? In in NC, I am around RTP a this week if anybody has one.
Thanks!
Old Apr 22, 2007 | 08:13 AM
jymontoya's Avatar
jymontoya
I got one! I'm in Winston Salem.... I'll rent it cheap!
Need a deluxe pulley removal tool as well?
Old Apr 22, 2007 | 08:36 AM
Kendel72's Avatar
Kendel72
Dont know where your from but stevecars60 is an awesome guy, he loanedme his and all I had to do was pay shipping both ways! Tensioner and puller.
Old Apr 22, 2007 | 09:50 AM
jhiggs26's Avatar
jhiggs26
Just use a 15 inch pry bar and lever it against a protected/buffered strut/chassis tower after your motor is raised! You will need a pulley removal tool though. Good luck!
Jeremy
Old Apr 22, 2007 | 04:07 PM
haji3's Avatar
haji3
Great, can I mail you a check for paypal for shipping and rent. I am trying to have it in before the first week in may for an event at VIR . I gott the pulley tool from Alta with the pulley.
I'll be forever grateful!
you can email me at Clinehall@suddenlink.net. I'm in Greenville.
Old Apr 22, 2007 | 04:08 PM
haji3's Avatar
haji3
Jeremy
Hmm, I think I will try with the tool. I tend to be very heavy handed and clumsy and well you get the picture!
Old Apr 23, 2007 | 12:22 PM
Glenns0245's Avatar
Glenns0245
im in the same boat... down in savannah ga... i see tons of MINIS around town but i dnt think i see any of them on here... but if any1 has the tensioner tool and remover to rent... thanks alot
Old Apr 23, 2007 | 01:12 PM
minimusprime's Avatar
minimusprime
You can avoid needing the tensioner tool with the following tools:
16"mm socket for use as a prying point
24" braker bar or pry bar.
Sae alen wrench that you you don't mind cutting the bottom part of the L off.
Little flat head screw driver or something thin and metal to put into the tension spring guide.
So you put the modified sae alen key into the hole on the tensioner where the pins in the tensioner tool are. you then put the 16mm socket on the bolt that is closest to the front of the car aka right above the sc. You then use the prybar or breaker bar as a lever one side above the 16mm socket and the long side below your modified sae alen key. Pry as described and place the little flat head in the slot in the metal piece in the spring guide.
As far as pulling the pully. I'd suggest the deluxe pully removal tool that I think out motoring sells. This is the easiest one to use as you don't technically have to remove the tensioner but I'll be honest with you it's nice to have it removed so you can get a good look at how the pully is seated on the sc shaft.
If you have a pully removal tool and all you need is the tensioner tool I can snap a few pics so you can get a better idea of my alternative method.
*e
Old Apr 23, 2007 | 01:18 PM
COOP310's Avatar
COOP310
I used the alternate method and it worked just fine. There is also a post somewhere with a diagram of how to build a tensioner tool
Old Apr 23, 2007 | 01:40 PM
xsmini's Avatar
xsmini
I did mine without tensioner tool when installing my pulley. But later when replacing the belt I had to buy a tool. (not quite as much access when the engine isn't lifted )
Nik
Old Apr 23, 2007 | 01:45 PM
minimusprime
Nik
I am able to use the method I spoke about above with the engine both in place and jacked up. I change belts using this method.
Old Apr 23, 2007 | 01:51 PM
xsmini's Avatar
xsmini
Good to know, I just wasn't clever enough to figure it out.
Nik
Old Apr 23, 2007 | 05:55 PM
haji3's Avatar
haji3
So you put the modified sae alen key into the hole on the tensioner where the pins in the tensioner tool are. you then put the 16mm socket on the bolt that is closest to the front of the car aka right above the sc. .
*e
Are you talking about the bolt that is on the tensioner itself? I don't have enough clearance to get the socket in there. Does the engine need jacked up first? How far can you raise it.
Old Apr 23, 2007 | 06:17 PM
minimusprime
I'm going to go out in the garage and snap a few pix. Expect them here by morning.
Old Apr 29, 2007 | 08:30 PM
apexer's Avatar
apexer
Sure would like to see those pictures
Old May 15, 2007 | 04:24 PM
OSUBeaver's Avatar
OSUBeaver
minimusprime, did you ever get a chance to snap some pics of your alt method? I'm curious to see it !
Old May 15, 2007 | 05:10 PM
minimusprime
yeah I did but I got lazy and just emailed them. Here's a copy paste of my email post if you have questions.
Originally Posted by minimusprime
alright here are the pictures.
In the first one you will see it kinda from the side. You can see the bolt that I put the 16mm socket on as a leverage point. The other chromed tool is a extension magnet just so i could snap the pics without dropping the cut off allen wrench. I just simply cut the bottom of the L of a #5 allen wrench. I just put it in the lower of the two holes. Then of course the 24" harbor frieght braking bar. Removing the fuel pressure thingy is advisable before doing this.
The following pics are the same at different angles and focus. I was having a hard time getting a good shot so... this is the best i could muster.
So you just pry it up and then you stick something into the spring guide on the actual belt tensioner. I usually go to the second hole. You've got to put some soft elbow grease prying on the socket like that. It's definitely a brute force solution but I've done it enough at this point with no wear on the bolt nor the tensioner. Now that you have the tensione released you can either pull the tensioner or just slap the puller on there. I had the deluxe puller that out motoring sells. the one with the cup on it. So I did not have to actually pull the tensioner. http://outmotoring.com/deluxe_superc...oval_tool.html
good luck and ill be in touch if you run into problems... I don't imagine you'll have any.
http://i188.photobucket.com/albums/z..._3665Large.jpg
http://i188.photobucket.com/albums/z..._3669Large.jpg
http://i188.photobucket.com/albums/z..._3672Large.jpg
Old May 15, 2007 | 10:03 PM
OSUBeaver's Avatar
OSUBeaver
Great thanks! I think I'm almost ready to give this a shot.
Old May 23, 2007 | 06:23 AM
bluesmini's Avatar
bluesmini
If you're going to track your car go ahead and buy the tool. I think they are 75 bucks or so. I've had to change belts at the track a few times. it's a 1 hour process with the tool and many frustrating hours without it. I've done it without and it sucks. Do yourself a favor and get one.
Old May 23, 2007 | 07:22 AM
minimusprime
eh to each their own. I agree with you that in track situations you need efficient tools but I can swap belts in under 30 minutes with my method. The longest part is removing the wheel well.
Old May 23, 2007 | 07:43 AM
bluesmini's Avatar
bluesmini
I've never removed the wheel well. I guess that could make things easier to get to.
Old Jun 15, 2008 | 10:21 PM
stef.v's Avatar
stef.v
puller and tensioner rental
Hello, I am looking to rent a pulley removal tool and the belt tensioner. I have bought the 15% reduction KMT pulley and can't wait to install it
I could pay the rent and shipping costs by Paypal. The only problem is I live in Romania, but I will be the one supporting the shipping costs.
If you can help, please pm me or e-mail savoinea [at] yahoo [dot] com
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
pahg
Oct 5, 2015 11:50 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
