Drivetrain P1684 what does this code mean?
Old Apr 18, 2007 | 06:52 PM
MarioKart's Avatar
MarioKart
Vendor
I plugged my car to an OBD II reader and it came up with this code P1684 but I have no idea what it means. Can someone help me out?
thanks
M
Old Apr 18, 2007 | 06:56 PM
Guest's Avatar
Guest
thanks
M
Bentley Manual: P1684 = Electronic throttle control monitor level 2/3 clutch torque min error. Not sure what it means...
Old Apr 18, 2007 | 07:04 PM
MSFITOY's Avatar
MSFITOY
Clutch slipping...
Old Apr 18, 2007 | 07:13 PM
MarioKart's Avatar
MarioKart
Vendor
my clutch is new and has about 1000miles on it.
Old Apr 18, 2007 | 09:26 PM
Guest's Avatar
Guest
Originally Posted by MSFITOY
Clutch slipping...
Sounds like it has more to do with the E-Throttle than the clutch. 2/3 torque and all that, not sure what it means. Unless the clutch wasn't properly broken in your clutch shouldn't be slipping. Stick the car in 5th or 6th at 55-65 mph and slam the gas to the floor, if there's hesititation, your clutch is toasted, if it catches right away and starts accelerating, it's fine. You can also try putting the car in first and letting the gas out slowly. If the clutch is on it's way out the car may not die when you let it out. Do you have a CEL on or you just randomly pulled a code .
Old Apr 18, 2007 | 10:54 PM
MarioKart's Avatar
MarioKart
Vendor
The CEL was on before I pulled the code. The clutch grabs fine and is smooth. I'm guessing the code is old because it have been on for over a week now. When clutch was first installed it had a bit of oil on it, but was cleaned with solvents, and reinstalled. The clutch did slip a tiny bit in third under load but that problem seemed to burn away.
M
Old Apr 18, 2007 | 11:00 PM
Guest's Avatar
Guest
M
Clear it and check again in a week or two. You're probably right.
Old Apr 18, 2007 | 11:03 PM
Guest's Avatar
Guest
Clutch slipping...
On a tangent. Do our cars actually throw codes when the clutch is slipping and needs replacement? That's sorta cool .
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
