Drivetrain Twin Charged and Cams?
Old Mar 20, 2007 | 04:51 PM
FastBandit's Avatar
FastBandit
Anyone out there running a twin charged setup with an upgraded cylinder head? Just curious to what Valves and Springs along with what Camshaft you are using.
Old Mar 20, 2007 | 05:07 PM
MarioKart's Avatar
MarioKart
Vendor
As of now I have the JE oversized pistons, Fireballed head and Cam. I want to go twincharged but I'm feeling a little uneasy. I should be safe because I have bulletproof pistons and a very flowing head, so to make the 270whp I want I should be able to run less boost causing less strain on the motor.
M
Old Mar 21, 2007 | 12:07 AM
AZMCS's Avatar
AZMCS
M
Come on Mario, go turbo-only. 17psi and 300 wheel
To answer the OP. I am gonna run a stock cam with the Fireballed stage 1 head. You can do a DMH head or a Fireballed stage 2 with uprated valves, reainters, guides and springs. But unless you want to see the far side of 7500 rpns ( I don't on my daily) then it is probably overkill.
BTW, it is a cam not cams. 16 lobes, one cam, loads of fun
Old Mar 21, 2007 | 04:25 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
M
I reality it isn't psi of boost that puts the strain on the motor, it's the tuning/timing/a-f ratio.
Old Mar 21, 2007 | 04:28 AM
Tüls's Avatar
Tüls
Turbius Maximus
and poor fuel quality
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
papawhiskey
Sep 30, 2015 02:50 PM
