Drivetrain Alta upgraded fuel pump?
Old Feb 26, 2007 | 01:55 PM
Peter W.'s Avatar
Peter W.
Can anyone give me the pros and cons to installing the new Alta fuel pump? What kind of modifications would work best with this new fuel pump? Is it only for twincharged and turbo only cars? Thanks
Old Feb 26, 2007 | 02:06 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Alta has an upgraded fuel pump...??
interesting!!
I'll go check Alta's website right now!
Old Feb 26, 2007 | 02:15 PM
DarkMiniCooperS
From what I have read, only twincharged and 19-23% pully'd cars will see benefits from this upgrade...
I sent an email to Alta to get further info.
You might cost me a fuel pump lol
Old Feb 26, 2007 | 04:10 PM
Peter W.'s Avatar
Peter W.
I have the 19% pulley with the 380cc injectors and GIAC remap. I am real interested in this product also but have no idea what the pros or cons would be. If you can find out some info and post it that would be great. Maybe we can do a group buy and get a discount. Hope to hear from you soon.
Old Feb 26, 2007 | 04:15 PM
herbie hind's Avatar
herbie hind
seems like they're running outta crap to sell .
Old Feb 26, 2007 | 05:28 PM
Trickle X's Avatar
Trickle X
I wouldnt run the 255lph pump unless you calculated its neccessity. I dont think you need it for 380cc, but if you would run 500 or larger then yes. There was a calculated thread a bit ago if you do a search.
The main issue I have with the pump is, it sits higher in the pump carrier than the stock. I have ran out of fuel about 4 times since running this pump. If you go this route, you will want to fuel around 1/2 tank to be safe.
here is a great link for calculating fuel injector size. From this you can derive what flow pump you should be running.
http://www.rceng.com/technical.htm
Old Feb 26, 2007 | 05:43 PM
Peter W.'s Avatar
Peter W.
Would it be a waste of time and money for me to switch my 380cc injectors for larger ones plus a bigger fuel pump? My car has the 19% pulley, 380cc injectors, GIAC computer remap, alta intake, WEBB exhaust, JCW engine package. Any info would be great. Thanks
Old Feb 26, 2007 | 05:58 PM
DarkMiniCooperS
I've asked Alta and, as usual, they were very helpful!
Here is the answers I got:
Thank you for asking. Yes the pump will be very helpful in keeping those injectors well fed at the higher RPM's. This should add several HP in that range.
First time installer expect 1-2 hours. It is very straightforward.
If we can help in anyway further PLEASE let us know.
Thanks for choosing ALTA Performance Products.
Old Feb 26, 2007 | 08:10 PM
onasled's Avatar
onasled
I'm no motor head to say the least, but isn't the last thing you want to do to add HP in the higher RPM range is add fuel? I mean the problem is that the ECU is already dumping to rich a blend at the higher RPMs, thus causing that annoying flat spot and HP drop.
To date I have not heard of anyone losing fuel pressure with a 19% pulley, but again, what do I know. I leave this up to those that I call on the phone ..
Old Feb 26, 2007 | 08:12 PM
Trickle X's Avatar
Trickle X
Honestly I would say no. Not until your getting close to 300bhp would I consider upping the fuel pump. Have you dynoed the car by chance? If not what to you calculate your bhp is? From this we can estimate what size injectors you need. I honestly think you are close enough with the 380cc in your current setup, but without knowing your bhp its all a calculate guess at best. If you run it on the dyno you can also check your a/f ratios. If your ratios are fine, then larger injectors really wont help much unless you have a way to control the fuel delivery to them. Even so, your only talking a few hp or torque here and there, not worth the cost imho.
Old Feb 26, 2007 | 10:29 PM
AZMCS's Avatar
AZMCS
Ryan spillman has stated he has run up to 32psi without running out of fuel from the stock system. Done on a dyno. Also consider there are plenty of twin-chraged cars out there with mega miles on them with the stock fuel delivery system....
Old Feb 26, 2007 | 11:06 PM
Paul Webster's Avatar
Paul Webster
we've made 300 to run 114 in the 1/4 and the pump has been okay, and don't fotget this is in a real world environment with accelerating g forces trying t o push the petrol back in the tank .
Old Feb 27, 2007 | 12:31 AM
Trickle X's Avatar
Trickle X
Yup guys, well aware.
Old Feb 27, 2007 | 08:44 AM
Peter W.'s Avatar
Peter W.
I have not yet dynoed my car but stock JCW says 200bhp, and after all the goodies i put on my car I would say I am at about 230-240bhp maybe. So I guess this product would serve no benefit if twincharged cars don't need it, so why would I, . Just wanted to spend a little money, maybe I will look into something else like an OBX header. I appreciate all the replies and info supplied.
Old Feb 27, 2007 | 08:50 AM
DarkMiniCooperS
What mods do you have??
Old Feb 27, 2007 | 09:12 AM
Peter W.'s Avatar
Peter W.
My car has the 19% pulley, 380cc injectors, GIAC computer remap, alta intake, WEBB exhaust, JCW engine package, Detroit tuned bypass valve.
HaveATank
Sep 4, 2015 08:04 AM
scottrn
Aug 22, 2015 07:26 PM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
Dsinkster
Aug 17, 2015 03:24 PM
kpl
Aug 11, 2015 04:52 AM
