Drivetrain Yep...
Old Feb 20, 2007 | 08:41 AM
  #26
Bahamabart's Avatar
Bahamabart
Originally Posted by CmdrVimes
The tune took it from ~190whp to 223whp. By my calculations that's only a 33hp difference.
sorry about that must have crossed Whp and Bhp somewhere.
Old Feb 20, 2007 | 08:47 AM
  #27
Bahamabart's Avatar
Bahamabart
what can you do or seen (program wise) with
1) a stock MCS
2) basic mods - 15 pulley/cai/catback?
Just trying to get a base understanding. This car is heavily mod so I am having problems getting a sense of the 30+ gain.
How much is said program?
Old Feb 20, 2007 | 09:29 AM
  #28
Scrappy's Avatar
Scrappy
Understanding flow maps...
I know it's been posted before, but here's a link: http://www.automotivearticles.com/Turbo_Selection.shtml
Old Feb 20, 2007 | 11:45 AM
  #29
62Lincoln's Avatar
62Lincoln
Congrats for an outstanding tune! Do you know what the peak torque was prior to the tune? Did the ecu tune alter the nature of the torque peak (earlier in the curve)? Great job!
Old Feb 20, 2007 | 01:32 PM
  #30
myzamboni's Avatar
myzamboni
1) a stock MCS
Just from following CmdrVines other threads, I think it's the LDG head and the ECU tune that got the 30+ gain.
Old Feb 20, 2007 | 01:38 PM
  #31
herbie hind's Avatar
herbie hind
what kind of dyno is that? where does it fall compared to others? those are great numbers but with so many stles of dynos it gets confusing.
Old Feb 20, 2007 | 02:34 PM
  #32
AZMCS's Avatar
AZMCS
good numbers. Ultimately when you tweek for max performance the concern needs to be AFR. Looks like you guys were able to get a nice flat result there. And if I assume correctly those are post-cat AFR's so adjusting ~1 for that gets you below 11.5 for the entire range. Nice.
Old Feb 20, 2007 | 05:21 PM
  #33
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
From stock to 190whp was the pulley, intake, cylinder head, exhaust header, injectors, cam.
From 190whp to 223whp was the tune.
Old Feb 20, 2007 | 06:03 PM
  #34
Wake|MCS's Avatar
Wake|MCS
What you also have to understand is that full potential of the head is taken advantage of with the ECU tune. That is another reason why the change was so drastic with the ECU tune. At least from what I have gathered... I don't doubt the numbers as you have a nice set of mods. People just don't know exactly how much power can be had from a REAL ECU tune done on the dyno. Once again, congrats!
And, LDG, how much for a custom tune?
EDIT: stock intercooler I suppose correct? Have you considered meth/water injection?
Old Feb 20, 2007 | 07:28 PM
  #35
astrochex's Avatar
astrochex
02///MCS
His intercooler is not stock....
It's a drop in replacement for the stock. Uses the stock mounting points (with brackets for the back). It doesn't bang into the bonnet (or even come close) like some others on the market. It usually runs 10 degrees F above ambient.
It also looks something like this:
If you want to know more you can either PM "luckdoggarage" here on NAM or give them a call at 410-489-0230.
Old Feb 20, 2007 | 08:59 PM
  #36
Longboard Mini's Avatar
Longboard Mini
Wow, I pulled 193.5WHP with the following two weeks ago:
15%
Alta CAI
DT Bypass valve
OBX header
Milltek
DFIC w/AeroGel Mat
Stock ECU
Stock Head
My new head should be done this week (specs soon). The custom cam with adjustable cam gear are done. The custom header, designed to match the flow of the head, starts later this week. The new 3" exhaust in about two weeks. The new ECU tune (more info later) should be here in about three weeks.
The first Dyno was to give a base. We (my tuner and myself) will be doing Dyno pulls after each mod along the way and will show it all soon. Good or bad.
Longboard
MOTE
43
Dec 22, 2009 02:45 PM
Thumper460
Dec 8, 2008 11:28 AM
CR&PW&JB
May 8, 2008 02:43 AM
ImagoX
Dec 23, 2007 09:23 PM
ImagoX
Sep 13, 2006 09:32 AM
