Drivetrain Yep...
Old Feb 19, 2007 | 03:33 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Yep...
Installed, Tested, and Tuned by Lucky Dog Garage
Old Feb 19, 2007 | 03:53 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Huh??
Old Feb 19, 2007 | 04:06 PM
Krut's Avatar
Krut
223 HP at the crank or the wheel Matt?
Old Feb 19, 2007 | 04:13 PM
Maxicooper's Avatar
Maxicooper
This is "The BEAST" ....
Old Feb 19, 2007 | 04:47 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Wheel.
The torque figure in the graph is wheel torque so it's 4.615 (4th gear) * flywheel (and some drive train loss).
Run on a Dynapack.
Old Feb 19, 2007 | 04:54 PM
Maxicooper's Avatar
Maxicooper
Originally Posted by CmdrVimes
Wheel.
Run on a Dynapack.
223.38 whp. Conservatively thinking, 12% drivetrain loss = 250.18 hp at the crank.
Definitely, an EVO killer.....
Old Feb 19, 2007 | 05:12 PM
Longboard110's Avatar
Longboard110
list of mods please
Old Feb 19, 2007 | 05:15 PM
moreorless's Avatar
moreorless
Well Done, Commander!!
Old Feb 19, 2007 | 05:17 PM
TampaMCS's Avatar
TampaMCS
Nice numbers and congrats!
Old Feb 19, 2007 | 05:19 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Originally Posted by 483FITTER
list of mods please
I guess I can't be completely vague about everything...
15% pulley
MINI Madness Exhaust Header V2 (I think, it looks different from the pics on the website)
Shrick Cam
380cc Injectors
Lucky Dog Garage Intercooler
Lucky Dog Garage Cylinder head
Lucky Dog Garage custom ECU tune
Without the ECU tune it was running sub-200whp, around 190 or so. The flash got it to 223. Also my redline was bumped to 7200 (at least last time I checked, it might have been changed again) and the dyno graph cuts off at 7000 and the HP numbers were still climbing.
I'm not running any piggyback computer at all, everything is handled through the stock ECU. So I didn't lose any functionality from a stock car. My only issue with breaking the wheel loose at 6000 RPM.
Oh yeah, I'm still running a stock exhaust. I get rid of that and I imagine a little more power will be freed up.
Old Feb 19, 2007 | 05:59 PM
SayGoodbye's Avatar
SayGoodbye
Any info on the intercooler?
Nice numbers...must be a blast to drive
Old Feb 19, 2007 | 06:10 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
It's a drop in replacement for the stock. Uses the stock mounting points (with brackets for the back). It doesn't bang into the bonnet (or even come close) like some others on the market. It usually runs 10 degrees F above ambient.
It also looks something like this:
If you want to know more you can either PM "luckdoggarage" here on NAM or give them a call at 410-489-0230.
Old Feb 19, 2007 | 06:37 PM
SayGoodbye's Avatar
SayGoodbye
Thanks!
Old Feb 19, 2007 | 07:51 PM
Wake|MCS's Avatar
Wake|MCS
Damn nice numbers! Congrats. You really chose a good list of mods that all work together flawlessly... Yea get a custom exhaust and you will be over 235whp for sure..
Old Feb 19, 2007 | 08:11 PM
DarkMiniCooperS
Great dyno!!
The torque numbers are way off... 700 lol What are the numbers at the wheels please??
Great job.
Old Feb 19, 2007 | 08:24 PM
kapps's Avatar
kapps
Originally Posted by DarkMiniCooperS
Great dyno!!
Great job.
You have to divide by the gear ratio to get wheel torque. Looks like almost 180 lb*ft at the wheels.
Old Feb 19, 2007 | 08:25 PM
SayGoodbye's Avatar
SayGoodbye
His chart on the bottom says 177 lb/ft.
Old Feb 19, 2007 | 08:37 PM
DarkMiniCooperS
Thanks guys!!!
Old Feb 20, 2007 | 07:26 AM
Bahamabart's Avatar
Bahamabart
did you ever run a base dyno (pre-mods) on this car? I don't doubt that your car is very strong but those mods can't produce 250 BHP.
Old Feb 20, 2007 | 07:33 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I think the LDG tune has a lot to do with it. He said he was putting down around 190 without it.
Old Feb 20, 2007 | 07:39 AM
luckydoggarage's Avatar
luckydoggarage
You're absolutely half right. The components themselves only provide a mod to the base ve of the engine and the result is about 190whp. The real increase came from a custom recalibration of the ecu to take advantage of the increased(altered) ve. It has taken a couple of years of steady development to get to this point. I don't think that there are too many other Mini tuners that are getting these kinds of results using only the factory ecu. Note the torque curve and the AFR data. The dynapack dyno I have gives hub torque but the flywheel numbers are there too.
Old Feb 20, 2007 | 07:43 AM
Bahamabart's Avatar
Bahamabart
I don't doubt that this is one strong Mini and I also don't doubt that you produce a great ecu tune but (and I don't think your saying this) but a tune alone adding 60hp?
Old Feb 20, 2007 | 07:46 AM
tdm156's Avatar
tdm156
Ruling the curves
Those are some awesome numbers from the mods that you have.
Old Feb 20, 2007 | 08:04 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
The tune took it from ~190whp to 223whp. By my calculations that's only a 33hp difference.
Old Feb 20, 2007 | 08:17 AM
luckydoggarage
It's really pretty simple and we've been doing it on other vehicles for years. The engine is just an air pump. By it's design , it has certain properties. If you change those properties, especially on a boosted engine(supercharged/turbocharged) you need to change the values in the equations PV=NrT that the operating system is crunching to make the vehicle run. The better we are at making those changes, the more power that the engine will produce and the better it will pump air.
