Drivetrain Invidia exhaust installation ?
Old Feb 6, 2007 | 06:39 PM
ittybittymini's Avatar
ittybittymini
Ive been researching this exhaust and have seen in older posts that there was a problem with the hanger needing to be modified on an '05 MCS.
Does anyone know if there have been any changes/upgrades on the Invidia N1 (part #HS03MCSGTT) that allow installation without modification?
Old Feb 6, 2007 | 07:35 PM
sprp85's Avatar
sprp85
I doubt there has been any updates on the exhaust design..
well. Easy way? Take off the inner hangers from the car. (they are just bolted on so they are very easy to take off) When the hangers are off, tie the hangers on the exhaust with zipties or metal wires... (using the empty holes that you have made by taking off the inner rubber hangers from ur vehicle).
They won't fall off.
Old Feb 19, 2007 | 04:08 PM
ittybittymini
Thanks for your reply.
Just in case anybody else wants to know, I ended up finding that Invidia makes an exhaust that fits 04-06 models. I purchased it from coasttocoastusa. Just got it, but haven't had it installed yet.
Old Feb 19, 2007 | 05:07 PM
Alex@Helix's Avatar
Alex@Helix
If you have any questions, give us a call. Ralph has the Invidia on his car and could probably answers any questions you might have
Old Feb 19, 2007 | 07:18 PM
shooler's Avatar
shooler
I have the Invidia for my 05 with the correct hangers and it fits perfect. I have had it on for approximately 7k miles with no problems. It's been a great exhaust so far.
Old Feb 19, 2007 | 08:57 PM
ittybittymini
Well, Friday is the big day...Invidia Exhaust, Alta CAI, M7 16%, M7 180°, colder NGK spark plugs
Old Feb 19, 2007 | 09:07 PM
Ralph@Helix's Avatar
Ralph@Helix
There are two versions, one for older(02-03) and one for newer(04+) models. If you get the correct one then you shouldn't need any hanger modifications.
Old Apr 20, 2007 | 12:35 PM
RacebyDesign's Avatar
RacebyDesign
Sorry to place my imput on an older thread:
Two systems available per Invidia:
2003-2004 MCS Cat-Back (per Tom Tran will fit 2002 models)
2005-2006 MCS Cat-Back
The hanger modification was a must prior to the new system being released. Now the only ones that cannot install this are the turbo guys.
Cheers,
Old Apr 20, 2007 | 08:06 PM
Pashigian's Avatar
Pashigian
The only thing to watch for is convertibles! I have an '06 MCS 'vert and installed a 02-04 invidia exhaust from an old mini of mine and the brace under the convertibles changed it from a simple hanger switch to a whole project.
Otherwise would have been very easy!
Old Apr 22, 2007 | 03:12 PM
RacebyDesign
Thank you. That is a very good note to make.
Old May 4, 2007 | 03:51 PM
Vernon29RW's Avatar
Vernon29RW
What about part numbers...i'm curious about the part number ittybittymini posted in the beginning. Does that number (HS03MCSGTT) fit only the 02-04 cars or does that fit the 05-06 cars and if it doesn't fit the 05-06 cars what is the correct part number to be ordering?? Any help from our vendors would be much appreciated.
Steve
Old May 4, 2007 | 05:58 PM
latte hiatus's Avatar
latte hiatus
HS03MCSGTT fits 02-04
HS05MCSGTT fits 05-06
HTH!
Old May 4, 2007 | 07:25 PM
Vernon29RW's Avatar
Vernon29RW
hey thanks alot for the help with the part numbers....much appreciated!
squawSkiBum
Oct 2, 2015 09:21 AM
Bennyboy
Aug 18, 2015 07:28 AM
Colt45Magnus
Aug 13, 2015 11:18 AM
ASRman
Aug 13, 2015 09:33 AM
