Drivetrain Aquamist Water Injection
Old Feb 1, 2007 | 11:38 PM
DuckWerks's Avatar
DuckWerks
Since the eom IC can be overwhelmed in higher state tuned cars, I was wondering whether anyone has or considered using water injection like the Aquamist systems on the minis. Thanks in advance
p.s. sorry if I missed some thread but I tried seaching without much success.
Old Feb 2, 2007 | 12:00 AM
Dr Obnxs's Avatar
Dr Obnxs
Yes...
There are some who have systems that they like. Alta has released a system based on the Aquamist progressive... I guess you could build it yourself, but Alta did a nice job of packaging things together.
There are also diverter sprayers. Alta makes on for the stock IC as well as thier aftermarket ones, and M7 has one for the DFIC they sell as well.
Matt
Old Feb 2, 2007 | 03:59 AM
DuckWerks's Avatar
DuckWerks
Matt
Matt - thanks for the tip. I completely missed that one as i don't often visit the alta site
Old Feb 2, 2007 | 06:47 AM
cliff@coasttocoastusa's Avatar
Former Sponsor
Alta Progressive Water Injection System:
Im running a sale on these units right now. I have a few in stock. There is more information regarding this system on my site.
Follow this link to see pricing info on my site.
Old Feb 2, 2007 | 01:41 PM
herbie hind's Avatar
herbie hind
you can get a good system from snow's performance for 400.00 . just p.m. misfitoy as he has a hell of a nice system and it didn't cost his first born .
Old Feb 3, 2007 | 05:36 AM
Thumper460's Avatar
Thumper460
I just rec. my SNOW Meth/water system... should have it installed and test dyno on STOCK 06MCS in a few months ( sooner if I get off my butt!). After the stock base run.. I'm going to install the pulley/ My head and dyno again...
Just me.........................................
Thumper
Old Feb 3, 2007 | 07:34 AM
norm03s's Avatar
norm03s
Thumper
Looking forward to seeing your results
Old Feb 3, 2007 | 01:55 PM
DuckWerks's Avatar
DuckWerks
Thanks herbie - I had a look and they've got some fairly comprehensive systems and are well priced. Thanks for the tip
Old Feb 3, 2007 | 02:00 PM
TampaMCS's Avatar
TampaMCS
I just picked up a system from Coolingmist that installs in the boot. Going to do the install later this week (once I figure out where/how) to tap the nozzle.
Old Feb 3, 2007 | 02:11 PM
Thumper460's Avatar
Thumper460
James.. rocking!! I'll see if i can get Allblack to assist ( more like do it...lol) and maybe get mine in this week.... I also just got my Light bar.. ( more electrical...) I am putting them pump and res in the boot also !!
Snow says anywhere befor the t/b.. for theirs...
Thumper
PS: wanna dyno here in Jax?? or Tampa
Old Feb 3, 2007 | 02:20 PM
TampaMCS's Avatar
TampaMCS
I am going to install it tomorrow most likely....
Snow also says not to spray before the s/c, so that leaves me scratching my head.
I could dill a hole in the intake hose and spray into that, but not sure that is a great idea...
I will probably dyo down here. Maybe we can convice Leo to get off his **** and dyno "justacooper"
Old Feb 3, 2007 | 02:27 PM
Dr Obnxs's Avatar
Dr Obnxs
There are several locations to try...
Befor the TB is easiest, but the stuff will go through the SC and get churned pretty bad, then through the IC, then into the motor. One book I read really liked this because the little bit of water made a better rotor-case seal and upped volumetric efficiency a bit. If you do it after the SCbut before the IC, you squirt it into the hottest air and may vaporize the most, lowering temps but displacing oxygen with steam, and if you squirt it after the IC, you'll probably carry the most droplets into the chambers, not displacing as much air with steam. What's best? I have no clue as I haven't tested any. Search around. I think JLM did testing in the past on it. But I'd love it if you tried them all and let us know what you find out.... Mayby misfitoy already did?
Matt
Old Feb 3, 2007 | 03:06 PM
DuckWerks's Avatar
DuckWerks
Matt
Matt - I few of the local guys at VWVortex/Australia use the meth/water injection with quite some success on their track cars. They were recommending spraying after the ic as this had (in their opinion) the most turbulent airflow allowing greater dispersion & vapourisation.
Old Feb 3, 2007 | 05:11 PM
TampaMCS's Avatar
TampaMCS
one of the locations I have been considering is actually the bottom on the outlet side of my alta i/c - becuase it is easier to tap and I can hide the line...
I'd love to try them all, but dont want a million holes/plugs in my setup
Old Feb 4, 2007 | 08:34 AM
herbie hind
you could not only do one after the i/c but two in parellel . one on either side to insure you're getting it to all the cyl. just go smaller on each nozzle so you don't use too much . just a thought.
Old Feb 4, 2007 | 08:35 AM
herbie hind
not either side of the i/c (misfit did this ) i think he decided to go after the i/c only . bye either side i mean (of the exit horn).
Old Feb 4, 2007 | 01:04 PM
Thumper460's Avatar
Thumper460
OK.. i am a dummy.. I am "meaning " the exit horn, where you are talking TampaMCS. I am going to remove the i/c and see if there is any room , if there isnt then the outside of the exit horn...
Thumper
Old Feb 4, 2007 | 01:20 PM
CustomAV's Avatar
CustomAV
Sorry to jump in but I have been thinking about this.
I have the DFIC which tankfully has the option to tie in without drilling any holes. Which side would you do and why?
This is definitely an area that I have no expertise in so I will not profess to have any real knowledge.
thanks for any help.
chris
Old Feb 4, 2007 | 05:38 PM
TampaMCS's Avatar
TampaMCS
I did the install, check it out here:
https://www.northamericanmotoring.co...ad.php?t=91218
Old Feb 4, 2007 | 08:06 PM
trackster's Avatar
trackster
Great job ! It looks like the kit was $ 369 including the tank , is that correct? Man that is deal compared to the other systems I have seen on here. You have to give us a report on the results as soon as you have it dialed in. Is the amount of coolent a fixed deal or do you select what you want?
Old Feb 4, 2007 | 08:13 PM
TampaMCS's Avatar
TampaMCS
It is fixed, IE, what your pump puts out, it delivers, the $369 deal is not the progressive system.
I am going to tune it down to come on at 8psi tomorrow and see how it goes.
Old Feb 4, 2007 | 08:50 PM
trackster's Avatar
trackster
Excellant, please let us know how it turns out. What was the ball park figure for your setup if i might ask.
Old Feb 4, 2007 | 09:13 PM
TampaMCS's Avatar
TampaMCS
$369
Old Feb 4, 2007 | 11:02 PM
trackster's Avatar
trackster
$369
$ 369 and that includes the tank ? Hell of a deal . This is moving up on my to do list. Please keep us posted .
Old Feb 5, 2007 | 06:55 AM
TampaMCS's Avatar
TampaMCS
I talked to one of their techs this am (who read my thread since I posted a link to their site ) and he confirmed my thoughts that the clicking was the internal pressure switch cycling the pump to protect it (aka doing what it is supposed to.)
I also ordered this peice, the clog/water water flow nozzel:
http://www.coolingmist.com/detailmain.aspx?pid=05
I added this so I can see when water is flowing, as when I am under boost, the car is too loud to tell if the pump is running...
