Drivetrain Crush Zone on factory JCW exhaust
Old Jan 25, 2007 | 07:10 AM
THE ITCH's Avatar
THE ITCH
Has anyone noticed any difference from removing the factory crush zone on the JCW exhaust? Apparently this crush zone has been applied to all the factory JCW exhaust to accommodate a brace used on convertables. It appears to remove this crush zone you would need to have an exhaust shop weld in a bent piece of exhaust tubing. It just looks like this is a very restricted area in the exhaust but would like to here anyones opinion who have removed this, especially on a GP.
Thanks,Steve
Old Jan 25, 2007 | 11:31 AM
FUEGO's Avatar
FUEGO
I doubt it would make any difference. Sure the "shape" of the pipe changed to allow for the x-brace but it is still the same cross-section as the round pipe. It might induce some turbulence in the exhaust flow to the mufflers but it shouldn't be enough to make any difference since all the bends in the pipe start just behind that point.
When I removed my JCW resonator and replaced it with straight pipe I also considered removing the flattened area but convinced myself that it probably wouldn't make enough noticeable or measurable difference to justify the cost of replacing that section also.
Old Jan 25, 2007 | 01:46 PM
jaridp's Avatar
jaridp
Im positive taking the crush out makes a difference. I know of a JCW MINI racecar that showed a difference on the dyno by cuttting this piece out and replacing it with a non kinked piece. I will try and get direct dyno numbers...although it was only like 1 or 2 hp ( I think ) It made enough difference for them to do it again this year. I am about to do this on my GP as well!!
Old Jan 25, 2007 | 02:03 PM
THE ITCH's Avatar
THE ITCH
Jaridp
Thanks, I would appreciate it. I know that the circumfrance of the pipe stays the same even when it is crushed but boy they are really doing a number on it in that area. It's almost flat.
Steve
Old Jan 25, 2007 | 07:24 PM
enologuy's Avatar
enologuy
This may be a little out of context but....
when I swapped out my JCW for a Milltek (header, cat, resonator, cat-back) I was shocked to see how restricted the exhaust was due to the pinched area. Circumferance aside, it IS restricted. The Milltek system is a great improvement over the JCW in performance and sound. However, if not replacing the system, I believe it would be worth the money to have a shop replace the pinched section with a piece that matches the rest of the tubing.
Old Jan 26, 2007 | 05:13 PM
Bahamabart's Avatar
Bahamabart
I believe GTT makes a replacement piece.
Old Jan 26, 2007 | 05:25 PM
golfman's Avatar
golfman
Coordinator :: Alabama Motoring Society
Gtt?
jaridp's Avatar
jaridp
Its just a chunk of pipe..go to your local muffler shop and im sure for less than 40 bucks youre done.
Old Jan 28, 2007 | 02:44 AM
BFG9000's Avatar
BFG9000
Here's a picture of both the crushed area and how it looks after the modification. The replacement pipe needs to have a bend in it.
Old Oct 21, 2012 | 01:25 PM
JT///MC's Avatar
JT///MC
Removed both the crush and resonator this weekend off my GP and now I'm in love again! Love the new deeper and aggressive sound! Car also feels torquier for some reason. Gotta love how it pulls through the revs now!
Sexual Chocolate
Mar 31, 2019 08:02 PM
Longjas
Aug 24, 2015 06:06 AM
ASRman
Aug 13, 2015 09:33 AM
papawhiskey
Aug 10, 2015 09:31 PM
